11 FLTRX CR-575 cams - Road Glide Forums
post #1 of 14 (permalink) Old 11-13-2011, 09:23 PM Thread Starter
tj316's Avatar
2011 FLTRX 103 , Cycle - Rama CR-575 Cama , Zippers Hi-Flow air cleaner , TTS Master tuner & Bassani Road Rage II B-1 exhaust
tj316 is offline
post #2 of 14 (permalink) Old 11-13-2011, 09:38 PM
Did you pull the heads and do any work to them? What was the compression ratio. Wolud this cam work with 10 1/2:1 compression.
neversatisfied is offline
post #3 of 14 (permalink) Old 11-13-2011, 09:53 PM
I bet that runs reallly good. nice indeed.
jeff is offline
post #4 of 14 (permalink) Old 11-14-2011, 05:57 AM Thread Starter
tj316's Avatar
pulled no heads , just added cams , after I get out of warranty I'll go into the heads , port & polish , add a bigger throttle body and injectors, but I have 15 months of warranty left , it will work on your compression too , call Wes at Cycle-Rama these are very good cams
tj316 is offline
post #5 of 14 (permalink) Old 11-14-2011, 11:33 PM
Eric92's Avatar
Nice!!
Your performance mods and dyno numbers are very similar to mine.
2011RGC/VIVID BLACK/103
Eric92 is offline
post #6 of 14 (permalink) Old 11-15-2011, 04:15 PM Thread Starter
tj316's Avatar
THANKS , I am most happy with my curve , it hits at 2500 rpm's and doesn't fall off til after 5000 rpm's
tj316 is offline
post #7 of 14 (permalink) Old 11-16-2011, 08:33 PM
I have the same cams in my 110 and love them.
They did a great job tuning your bike nice looking dyno run.
CVO110 is offline
post #8 of 14 (permalink) Old 11-16-2011, 09:23 PM
Rowdy's Avatar
Great lookin numbers, can't go wrong with that set up. You can always improve, but that really depends on what your lookin when it comes to power...
Rowdy
Rowdy is offline
post #9 of 14 (permalink) Old 11-16-2011, 09:29 PM
bigpete1's Avatar
is the bassani the 2into 1 or duals ?if 2into 1 how is sound level ?been looking road rage 2 2into 1 for my roadglide ultra thanks pete
05 fltri 95" 06 fxdi 95"03 flht120" 11 fltrui 103
bigpete1 is offline
post #10 of 14 (permalink) Old 11-17-2011, 06:55 AM Thread Starter
tj316's Avatar
It's the Road Rage II 2-1 B1 , Bassani just released it in a B-4 version which they told me would produce better numbers on a 103 or 96 but I'm not buying another exhaust , it sounds great , nice deep rumble , barks when you get on it but not annoying when riding it
tj316 is offline
V and H 575 cams DABIGBOI220 Engine Related 1 07-21-2017 09:58 AM
Dave Mackie 575 cams or Fuel Moto 107 freedom1974 Engine Related 17 07-06-2017 05:38 AM
Cyclerama 575 cams Hammer Down Engine Related 10 11-14-2014 06:42 AM
Head quarters 575 cams sj01fltri Engine Related 7 10-07-2013 10:24 AM
Veterans Day 11/11/11 PittsDriver *General Road Glide Discussions/Pictures 17 11-11-2011 11:47 AM
