103" RGC with SE Stage 4 upgrade - Road Glide Forums
post #1 of 7 (permalink) Old 03-17-2014, 08:53 PM Thread Starter
McGruder's Avatar
Forgot to post my dyno sheet here. I upgraded to the SE Stage 4 kit, #92500005 (259e cam, 10.5 pistons, CNC ported heads, perfect fit push rods, high flow injectors, SE clutch springs), and dyno tuned using the SERT. I also had them replace cam bearings with Timkens.
Peak dyno numbers are 103 HP and 113 TQ. The power band walks a nice middle ground between a low end torque and top end racing profile.
2013 RGC - SE Stage 4, V&H Dresser Duals, Rinehart 4", Progressive Monotubes/Ohlins 357, Khromewerks Extend Heritage bars, Daymakers,
J&M 500W XTP amp, 4 Rokker XX speakers, BADDAD lids, Road Tech 665
McGruder is offline
post #2 of 7 (permalink) Old 03-17-2014, 09:03 PM
faststan's Avatar
Nice numbers. Probably a lot of fun to ride.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 7 (permalink) Old 03-17-2014, 09:15 PM Thread Starter
McGruder's Avatar
Thank you. The low end has good street-ability for casual riding and parking lot speeds, and is a beast from 3000 on up. Haven't really tested with my passenger, or taken it past 5000 rpms yet, but I am loving it.
McGruder is offline
post #4 of 7 (permalink) Old 03-17-2014, 09:46 PM
Nice curves!!! What's not to love???
HeatWave is offline
post #5 of 7 (permalink) Old 05-03-2014, 04:46 PM
ironmike666's Avatar
NICE! can only hope mine turns out this strong. Will it lift the front tire off the ground?
ironmike666 is offline
post #6 of 7 (permalink) Old 05-03-2014, 04:59 PM Thread Starter
McGruder's Avatar
I haven't lifted the front off the ground, but if you tach'ed it up to 4500 and slipped the clutch I bet it would leave the ground. I don't care for doing that to my crank, especially when I'm about to head south for 5 days through blue ridge parkway all the way down to Deals Gap and Cherahola Skyway in TN . The Stage IV build is still running great!
McGruder is offline
post #7 of 7 (permalink) Old 05-03-2014, 05:36 PM
I hear ya. I didnt think it was possible either. But thought i'd ask. The parts guy that sold me the kit is always asking if i've had mine off the ground. He says he's done it....popping the clutch probably.
Stage III 103 to 110 or Stage III Performance Upgrade? javal2001 Engine Related 0 06-04-2017 03:27 PM
SE Stage 4 for SE 110" '13 CVO RG Batbiker Engine Related 2 01-19-2013 12:22 PM
DYNO sheet 2011 RGC 103" Stage IV NHBOUNCER Engine Related 9 10-03-2012 05:48 PM
SE Stage IV 103 question abone Engine Related 114 09-01-2012 08:15 AM
