'13 CVO RG from Doc's and T-Man - Road Glide Forums
post #1 of 6 (permalink) Old 04-04-2014, 09:25 AM Thread Starter
Well it's been a year now and my scooter still runs as well as it did when I picked it up from Doc's. Pulls hard right from the start and continues up to 4,000 R's. Wondering what the trade off will be if I change cams? Adding more top-end torque might make it suffer in the low R's?
Ride it like you stole it!!
'13 CVO Road Glide Anniversary
Batbiker is offline
post #2 of 6 (permalink) Old 04-04-2014, 12:45 PM
Look at the T-Man 625s, they pull from down low to the redline.
From the Dyno sheets that I have seen, the 625s have really nice curves in 110s / 113s, they will really improve (extend) the operating range over the 255s. TR recommends 10.2 - 10.6 cr
'Am bringing the 625s to my Dealer today, for the 117 / DD7 Build in the '09 SERG.
'Am told that the 625s run pretty quiet.
HeatWave is offline
post #3 of 6 (permalink) Old 05-27-2014, 12:21 AM
North Star's Avatar
Don't know why you'd touch it if you like the way it runs, and since it was tuned by Doc, one of the best tuners anywhere.
I've spoken to him about his 110 builds like he did for you, but went with a local builder who, like Doc, recommends leaving in the stock 255 cams for the best low end torque- my builder re-degreed the cams, which I believe changes the valve opening and closings a bit.
Don't fall for all the internet hype- knowledgable, real world Harley builders like ours build and tune an engine by using a COMBINATION of work and parts which make the final product. I personally wouldn't mess with that combination- I'll bet you would be worse off.
North Star is offline
post #4 of 6 (permalink) Old 05-27-2014, 12:24 AM
North Star's Avatar
....and my numbers and curves are very similar to yours.
post #5 of 6 (permalink) Old 06-07-2014, 12:10 AM
unbalanced's Avatar
you might consider the 24d cam by Kuryakin. Typically with Sach's headwork they are making 120 squared and above. You wont give up that much on the bottom end. Many of the cvo's are going with this combination.
-Unbalanced
He who laughs last thinks slowest.
unbalanced is offline
post #6 of 6 (permalink) Old 06-07-2014, 12:24 AM
unbalanced's Avatar
These are just a few of them.
This cam will also lower the heat on the engine as it has more overlap and will give you the upper end too.
-Unbalanced
Factory 47 bars - what's the difference between CVO RG and non-CVO RG? roadie13 Controls & Handlebars 7 12-29-2017 06:36 AM
Hitch Doc trailer hitch 09-13 FLTR/FLHR ~NEW~ fragmentum Parts for Sale 9 03-18-2014 07:11 PM
Doc is a genius - 110" CVO '13 build Batbiker Dyno Results 4 03-22-2013 02:11 PM
My CVO 110" '13 back from Doc's Batbiker Engine Related 5 03-21-2013 09:36 AM
