14 FLHTK Cam Testing by Fuel Moto TW-222/555/777 - Road Glide Forums
post #1 of 14 (permalink) Old 05-05-2014, 12:29 PM Thread Starter
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Our cam testing from last week is finished up on the 2014 FLHTK. Tested the Wood TW-222, TW-555, & TW-777's vs stock cams. Results show very good gains with each cam. Each cam was tested with the same combination which included the Jackpot 2/1/2 head pipe, Jackpot mufflers, FM Pro billet air cleaner, and each setup was dyno tuned with Dynojet Power Vision.
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #2 of 14 (permalink) Old 05-05-2014, 12:39 PM
Redbeard77's Avatar
Interesting comparison, but isn't it unfair to the 777 (and probably the 555) to install it with stock compression?
Happiness is a warm motorcycle.
Redbeard77 is offline
post #3 of 14 (permalink) Old 05-05-2014, 02:16 PM Thread Starter
fuelmoto's Avatar
As you can see in the results that both cams work very well with stock compression. The 555 & 777 would make even more Hp/Tq at higher compression as do most combinations
Email
fuelmoto is offline
post #4 of 14 (permalink) Old 05-05-2014, 08:25 PM
Ohiobellboy's Avatar
You trying to tempt us for when the Wet Shark makes it to the market
A.K.A OBB
Ohiobellboy is offline
post #5 of 14 (permalink) Old 05-30-2014, 07:17 AM
From working with Bob Wood cams since the mid-1990's when Bob first brought his Evo cams to the V-Twin market, yes, the 555, and 777 both need more compression to fully optimize the potential of the later intake closing events of them.
Scott
Hillsidecycle.com is offline
post #6 of 14 (permalink) Old 05-30-2014, 11:22 AM
The TW222 are pretty impressive IMO. They don't make as much HP as the TW777 but the torque is real close to being the same. I am glad I am using the TW222.
post #7 of 14 (permalink) Old 05-30-2014, 04:46 PM
sj01fltri's Avatar
If using the 777's what would be the correct compression for this cam.
sj01fltri is offline
post #8 of 14 (permalink) Old 06-01-2014, 04:10 PM
equandt's Avatar
10.5 - 10.75
2012 FLTRX
2010 FLHTCU
equandt is offline
post #9 of 14 (permalink) Old 06-01-2014, 05:52 PM
Harleyagain's Avatar
Love my 222's
Bob
Harleyagain is offline
post #10 of 14 (permalink) Old 06-22-2014, 09:02 PM
im color blind as hell i can't tell which is which
desertrat702 is offline
2014 FLHXS Fuel Moto 107 build TW-777 cams fuelmoto Dyno Results 0 02-27-2014 12:19 PM
Sporadic knock at idle new tw-777 cam ChivoChavez321 Suspensions 6 10-26-2013 11:24 AM
2011 RG Fuel Moto 107" TW-777, 119Hp/125Tq fuelmoto Dyno Results 5 01-11-2013 08:01 PM
PC-V map for Woods TW-222 Cam Ghostrider Map Section 0 12-12-2012 09:15 PM
2012 103" Touring Testing Wood TW-777 Cams fuelmoto Fuel Moto 6 10-24-2011 04:50 PM
