Screaming eagle stage IV 103c.i. - Road Glide Forums
post #1 of 10 (permalink) Old 05-07-2014, 07:42 PM Thread Starter
ironmike666's Avatar
Little bit bummed.. I see tons of guys on here with way better numbers outta their stage IV's. Dyno and tune done at harley dealer on SERT.
102 hp and 99 torque
Straight up screaming eagle kit w 259e cams and S&S power duals and street performance mufflers(S.E)
ironmike666 is offline
post #2 of 10 (permalink) Old 05-07-2014, 08:58 PM
tdkkart's Avatar
First question, How does it run against those that show better numbers?? The thing to realize is that every dyno is different, and it's easy to make them show better numbers.
Put your bike on 10 different dynos and you will get a dozen or more different answers.
The loser of this game is always the first liar.
Do you have any idea where the actual air/fuel ratios came out, or does the dyno even have the ability to measure it?? A motor with everything else right won't run right if the fuel ratios are wrong, but it can still make a nicely shaped graph, just low numbers.
tdkkart is offline
post #3 of 10 (permalink) Old 05-07-2014, 09:54 PM Thread Starter
Im not sure where the tech set the afr's. I'd assume a little on the rich side??? No idea lol. Didnt ask. But they put the kit together and theres warranty so i'd assume they're running it a little on the safe side.
post #4 of 10 (permalink) Old 05-08-2014, 12:31 PM
neverdone's Avatar
On the stage 1 I had installed the dealer did the dyno. On the stage 4 they took it to a private tuner. I think the dealer stays on the safe side of things.
neverdone is offline
post #5 of 10 (permalink) Old 05-08-2014, 03:20 PM
Redbeard77's Avatar
It's hard to say much about your numbers without a "before" comparison on the same dyno. As stated, there's a good bit of variation, so you could take your bike to a different shop today and see a 5 hp "gain" without changing anything.
The key is rideability, so as long as that's good I wouldn't sweat the numbers too much. Or if you're not comfortable with it, take it to a trusted tuner and see if there really is power to be gained in the programming. Just be sure he gets a "before" reading...
Happiness is a warm motorcycle.
Redbeard77 is offline
post #6 of 10 (permalink) Old 05-08-2014, 05:00 PM
08Zinc's Avatar
DON'T BE BUMMED!!! If you like the feel of the bike after the Stage 4, then be happy. Agree with the others on the Dyno numbers. Just wick it up past 3000 RPM and hold on! In addition to the dyno's settings, other variances will be due to exhaust and intake choices as well as temps & humidity I believe. Love my Stage 4. Think you will too when you quit looking at the numbers and feel the difference.
Blessings, Zinc -
08Zinc is offline
post #7 of 10 (permalink) Old 05-09-2014, 12:28 AM Thread Starter
To be honest i need more off the line snap. Just doesnt pull like i was expecting. I really never rev it past 5,000rpm. Oh well gives me a reason to keep researching and wrenching. Its only money right. Need a project for next winter 😜
post #8 of 10 (permalink) Old 05-09-2014, 05:17 AM Thread Starter
The rideability is good. I really shouldnt complain. It feels good, just had higher expectations for the amount of bread i laid down for the kit.
And i do have plans for a before dyno and tune with the thundermax to see if we can gain some performance. Then probably a cam swap to move the curve left.
post #9 of 10 (permalink) Old 05-09-2014, 09:33 AM
neverdone's Avatar
I'm no expert but sound like you might want to go with some different cams. My power is at 2500 to around 5000 rpm. You might want to talk to Frank,Fuelmoto or Hillside and see what they suggest.
post #10 of 10 (permalink) Old 05-09-2014, 12:33 PM Thread Starter
Frank seems to be the "man". Its in the works. Startin with a thundermax. Probably dragulas, then cams and go from there. That should hold me over till winter. haha
Screamin Eagle Stage IV 2017 RGS dshudson Engine Related 11 04-27-2017 05:44 AM
stage 4 screaming eagle dyno IranAround Dyno Results 12 10-04-2012 11:00 AM
Screaming Eagle Stage IV Cam Change gbourdon Engine Related 13 10-13-2011 11:38 AM
screaming eagle stage 1 kit 2bagger Classifieds Archive (3 months old+) 2 06-14-2011 07:39 AM
Stage 1 & Screaming Eagle Exhaust buzzman_45011 Intake and Exhaust 4 05-17-2010 11:12 AM
