13 road glide 103 with 255 cams - Road Glide Forums
post #1 of 15 (permalink) Old 07-09-2014, 06:44 PM Thread Starter
13 road glide 103, sert, se255 cams, se ventalator, vance and hines power duels, cfr mufflers
Made 94 HP 116 torque
Not to bad for now
schlum13 is offline
post #2 of 15 (permalink) Old 07-09-2014, 06:55 PM
Craigmier's Avatar
Wow thats quite a bit higher than my setup which is identical to yours. Living in mile high city def has its disadvantages... Bet thats fun to ride
'13 FLTRX - Big Blue Pearl - 16" Carlini Gangster Apes - V&H Power Dual Headers - CFR's - SE255 cams - SE Billet Cam Plate w/High Flow Oil Pump - SE Billet A/C - SERT - Dyno Tune - Daymakers - LRB Carbon Black Rotors - Progressive Suspension - H-D Vented Lowers - Bitchin Stitchin Custom Seat - Rockford Amp - Infinity 6.5's - GADS
Craigmier is offline
post #3 of 15 (permalink) Old 07-09-2014, 08:59 PM
Mountainman's Avatar
Send a message via Yahoo to Mountainman
Smile Sounds Good!
Not to bad for now
Can we se that dyno? Sounds Great!
2013 FLTRU Big Blue Pearl:RB Racing LSR Spyder, SE255's (110/95), SERT, Boyesen Power x, DK intake vents,3"tank lift, t-pack relocator, Outlaw oil filter, Slipstream htd grips, l-s mirrors,adj backrest, 3t derby, sancho's wings, Ward's 160* thermostat, BigSky fans, Liquid Moly 10w-60, Rdeline VTwin Heavy Shockproof, B&M Trickshift, Burly ez clutch
Mountainman is offline
post #4 of 15 (permalink) Old 07-09-2014, 09:17 PM
Ohiobellboy's Avatar
only 1 hp less and the same torque as my 110 and I have nothing more than a D&D 2-1 and a sert. (same cams as my stock ones).
A.K.A OBB
Ohiobellboy is offline
post #5 of 15 (permalink) Old 07-10-2014, 08:05 AM
sloride's Avatar
Not to bad for now
Really great #'s
can you post the dyno chart?
sloride is offline
post #6 of 15 (permalink) Old 07-10-2014, 09:54 AM Thread Starter
It rips pretty good
schlum13 is offline
post #7 of 15 (permalink) Old 07-10-2014, 11:19 AM
kouack's Avatar
Do you have the SAE chart version also?
kouack is offline
post #8 of 15 (permalink) Old 07-10-2014, 12:00 PM
HellInABucket's Avatar
Also, I cant imagine thats a before/after picture, must have been just the final runs - ?
I'd expect a SAE-based correction factor would show it at about 110, depending on elevation and humidity at the time of the run. Still pretty damn good.
Power duals help a bit not sure how much vs 2-1-2, but it just goes to show you how much of a hit you take with true duals (meaning if he had true duals it would be much less. Guessing 101-105)
HellInABucket is offline
post #9 of 15 (permalink) Old 07-11-2014, 12:44 AM
Smile Fine looking dyno
Nice looking chart. Torque comes on soon and hard. Look at how fast the hp comes up... Gotta hate those 255 school bus cams.... LOL
post #10 of 15 (permalink) Old 07-11-2014, 09:48 AM Thread Starter
I don't have a sae chart, these were final numbers. I didn't get base numbers because he was behind.
13 black fltrx 103, sert, se255 cams, vance & hines power duels, cfr mufflers, 14" pm bars, 21" pm wrath front 18" rear and the list goes on
schlum13 is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
103 kit with 255 cams Orange09Glide Parts for Sale 1 01-03-2016 11:14 AM
255 vs 204 in a 103 Glidr Engine Related 9 10-10-2014 02:43 PM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
07 103" Roadglide, Stock Heads, 255's hdxbones Dyno Results 24 10-13-2012 02:10 PM
