Dyno - Road Glide Forums
post #1 of 10 (permalink) Old 07-29-2014, 05:09 AM Thread Starter
bikerglasses's Avatar
Dyno
Looking for a Map for a 2013 with ness big sucker and mgs true duals.
I have a dyno map but still have a pop around 2nd and 3rd and pinging on hard acceleration.
Let me know what you have.
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, 12' Twin Peaks, -1" Monotubes
bikerglasses is offline
post #2 of 10 (permalink) Old 07-29-2014, 08:37 AM
Can you not take it back to whomever performed the dyno tune for some corrections?
2012 Road Glide Ultra
79HP 103 TQ, tuned by Ed at The Dyno Difference.
tsigwing is offline
post #3 of 10 (permalink) Old 07-30-2014, 03:24 AM
Banned
Doesnt get much easier to tune a Power Commander and True Duals. A good tune is worth the money and effort to find the guy capable. If you got a bad tune on a dyno with a PC, thats not good. Is it possible you just got a bad (low octane) tank of fuel?
INDY #1 is offline
post #4 of 10 (permalink) Old 07-30-2014, 11:30 AM
If you want a base map send me an email we have something close to those that might help you out.
MGS are stepped duals.
Which mufflers are you running?
send me email @ [email protected]
DragoBikeWorks is offline
post #5 of 10 (permalink) Old 07-31-2014, 09:24 AM Thread Starter
Shop is 2 hrs away. Just dont have the time.
I've had this tune almost a year, and had a pop right after. But last few months seems worse and pinging. No sure if its just because it's a lot hotter here, but when the tune was done it was July or august and In PHX which is hotter then Tucson.
Just wish I understood maps and I'd play around with it myself.
post #6 of 10 (permalink) Old 07-31-2014, 09:26 AM Thread Starter
I'll shoot you a email, I appreciate it. I'm running MGS headers and pipes. Ness big sucker and pc5.
post #7 of 10 (permalink) Old 07-31-2014, 10:34 PM
Banned
So is the symptom you're describing with the "pop" when you shift, it's making the pop out the exhaust as soon as you some the throttle and grab the next gear? Are you changing elevation considerably while riding or from the elevation the bike was tuned at to the elevation you typically ride?
INDY #1 is offline
post #8 of 10 (permalink) Old 08-01-2014, 06:22 AM Thread Starter
Yah exhaust is popping 1-2, 2-3 gears. Elevation hasn't changed. Had dyno in Phoenix and I live in Tucson. I remember still having a pop after dyno, but don't remember the pinging until a few months ago when it started getting hot... Like I said pinging only seems like its happening on hard acceleration.
post #9 of 10 (permalink) Old 08-02-2014, 12:43 AM
Banned
Sounds like it may need retuned but if you add some fuel to the closed throttle area cells where the pop is in terms of rpm pop occurs, it may remedy the pop. If it's pinging on roll ons and you want to try something cheap other than paying for a new tune, you might try a new set of stock plug wires and plugs. Gap the plugs at about .036" gap and see if that helps. If it doesn't, you could try a colder plug gapped on the small side again. Until it's on a competent dyno operators dyno, it's hard to say. It could need more fuel on the accelerator enrichment table, it could need less timing somewhere or it could be both. You do have the O2 sensor eliminators installed that come with the power commander I assume?
INDY #1 is offline
post #10 of 10 (permalink) Old 08-02-2014, 02:00 AM Thread Starter
Yes I do have the eliminators installed. Thanks for the info. Frank also sent me a map to try. I'll have to call the shop again too.. Problem is they're a very reputable shop.
Dealership is not authorized to dyno 2011s??? Gadgetech *General Road Glide Discussions/Pictures 22 12-29-2010 11:40 AM
Good Dyno Tuner in Denver? RockyMtnRG *General Road Glide Discussions/Pictures 7 12-03-2010 11:28 AM
Dyno is done. thunderhorse *General Road Glide Discussions/Pictures 2 06-29-2010 04:41 PM
Dyno Run from Direct Link Install Shrug ECM/Fuel Management systems 6 06-07-2010 10:32 AM
Dyno run On You Tube pte359 *General Road Glide Discussions/Pictures 5 05-21-2010 08:48 PM
