107 RC cycle tune - Road Glide Forums
post #1 of 15 (permalink) Old 08-06-2014, 10:42 PM Thread Starter
Olskoo's Avatar
107 RC cycle tune
Just had my bike tuned by Dyno Bob at RC cycles in Hayward Ca. He's the man. 115 hp and 122 tq. Want to post a picture but it keeps failing.
Olskoo is offline
post #2 of 15 (permalink) Old 08-07-2014, 12:51 AM
NorCal's Avatar
Bob does a great job, what the specs on your motor??
NorCal is offline
post #3 of 15 (permalink) Old 08-07-2014, 01:41 AM
hd4cruzin's Avatar
I'm assuming you used TTS? Also did RC Cycles do the install of the 107?
Bob Does GOOD work!
2012 FLTRX BBP
hd4cruzin is offline
post #4 of 15 (permalink) Old 08-07-2014, 09:23 AM Thread Starter
Olskoo's Avatar
107 RC cycle tune
Motor specs; SE stroker flywheel welded and trued , timken bearing conversion ,ported big valve heads milled .010 with Crane 165# springs ,CP forged flat top pistons 10.5-1 comp. HPI ported 48mm throttle body with 5.3 gps injectors , S&S 570 cams , SE cam plate HV oil pump and hydro tensioners , S&S lifters , SE adjustable push rods , Barnett clutch with SE spring , baker primary adjuster , power commander 3. RC didn't build it only tuned.
Olskoo is offline
post #5 of 15 (permalink) Old 08-08-2014, 12:09 AM
hd4cruzin's Avatar
Nice build.
Enjoy!
2012 FLTRX BBP
post #6 of 15 (permalink) Old 08-08-2014, 12:16 AM Thread Starter
Olskoo's Avatar
Thanks , this thing rips front wheel comes up shifting into second gear
Olskoo is offline
post #7 of 15 (permalink) Old 08-08-2014, 06:55 AM
That .570 S&S cam works well, and Bob sure knows how to tune.
Scott
Hillsidecycle.com is offline
post #8 of 15 (permalink) Old 08-08-2014, 08:43 AM Thread Starter
Olskoo's Avatar
Yes I'm happy with my build Scott , I don't no if you remember but I called you about the cams prior to the build,and you told me those were the most under rated cams . Thanks for your help.
Olskoo is offline
post #9 of 15 (permalink) Old 08-08-2014, 08:18 PM
Marty33's Avatar
Hey Olskoo, who did your 107?
Marty33 is offline
post #10 of 15 (permalink) Old 08-08-2014, 08:47 PM Thread Starter
Olskoo's Avatar
Backroads custom cycles in Lathrop , I wouldn't recommend them had a lot of issues to get to where I'm at . Read some of my other posts
Olskoo is offline
RC/Xcelerator-RC components xbohntr ECM/Fuel Management systems 7 11-12-2015 01:56 AM
Screaming Eagle Stage 4, RC slip-ons, De-cated stock pipe, and pro tune GA ROADGLIDE Dyno Results 5 07-04-2015 08:08 AM
191HP 154 TQ Dragos Stage 3 107 Blower engine break in tune. DragoBikeWorks Dyno Results 8 08-06-2014 12:10 PM
Fuel Moto 107, Customer built, tuned @ RC Cycles fuelmoto Dyno Results 3 04-15-2014 01:19 AM
Custom Tune v. Tune in a Box? FLIronButtRider ECM/Fuel Management systems 62 02-01-2013 07:54 AM
