2009 Road Glide 96" - Road Glide Forums
post #1 of 5 (permalink) Old 04-22-2012, 01:41 PM Thread Starter
bikepsych's Avatar
2009 Road Glide 96"
Most recent dyno run on the Jett Tuning Dyno. Its the same Dyno that Rider Magazine uses.
Was a little disappointed in the final numbers so looking for recommendations to get it closer to the magic 3 digit realm.
The blue line was with PCV, SE Air cleaner, stock exhaust in December of 09.
The green line was the addition of an Andrews 54HCam, V&H True Duals, SuperTrapp FatShots with 12 discs and open end cap prior to tuning.
The redline was after PCV tuned.
Final numbers...80.69 HP and 88.09 TQ. Sitting around 40MPG hiway.
BG
bikepsych, 2017 RoadGlide Ultra
Supertrapp Fatshots, SE A/C, 107 2 114 kit
bikepsych is offline
post #2 of 5 (permalink) Old 04-22-2012, 01:47 PM
ZachB's Avatar
I have heard from more than 1 source the 54 is better suited for a 103. With a 10:1+ comp witch I'll be working on myself next year.
2015 RGS 103" Denim Black, Drago's 2:1, SE Heavy Breather, SEPST, Tuned. That will do for now.
ZachB is offline
post #3 of 5 (permalink) Old 04-22-2012, 02:05 PM
TXcruiser's Avatar
You're gonna need cubes and compression. Going 107 is the same cost as 103 when you're starting with a 96.
Looks like a nice smooth graph, how does she run now?
'12 FLTRX
TXcruiser is offline
post #4 of 5 (permalink) Old 04-22-2012, 05:10 PM
There is something wrong. Your tune looks OK, but the power curve shouldn't drop off like it does.
My bike was a similar build but built HP smoothly to 6200 & 85 HP.
rc_chico is offline
post #5 of 5 (permalink) Old 04-22-2012, 07:38 PM Thread Starter
bikepsych's Avatar
Seems to be running good with the exception of fuel mileage which is down around 35 right now. Not a happy camper about that.
One thing I did change since that final run was changing out the open end cap for the closed end cap and adding 6 discs. Neighbors were giving me the stink eye when I'd go buy on my way to work. Seems to have quieted down some but still need to get the ponies back up.
The 107" kit is definitely on my radar.
BG
95", 96", or 98" Iron1 Engine Related 12 01-14-2017 05:04 AM
Need map for 2010, 96", v&h dresser duals, rush 3.5", 2" baffle ilmanzo31 Map Section 3 07-28-2016 03:52 PM
Need a map for a 2009 96" StrokerAce Map Section 0 02-19-2014 09:40 AM
2009 Road Glide "Blanca" FLTR AL Road Glide Builds-Document your builds HERE --NEW 13 11-18-2012 08:10 PM
