Screaming Eagle 204 Cam - Road Glide Forums
post #1 of 1 (permalink) Old 10-26-2014, 09:24 PM Thread Starter
david-h's Avatar
2012 FLTRX, Screaming Eagle 204 cam, Screaming Eagle Air Cleaner, Vance and Hines Pro-pipe and SERT tuner. This set-up sounds and runs great. It has a really nice idle. Pulls from 2500 right on thru 4000 rpm. I ended up having to get the screaming eagle clutch spring because the clutch was slipping a little.
Max Power: 85.70
Max Torque: 96.08
2012 FLTRX
david-h is offline
Need a pcv map 103 with se 204 cam waffler ECM/Fuel Management systems 0 04-30-2016 01:07 PM
SE 204 Cam Powervision tune kiohio Map Section 7 12-26-2014 08:11 AM
Wtb S/e 204 cam set x52gnr Wanted! (Buy or Trade) 0 07-30-2013 12:01 PM
Brand new SE 204 cam & pushrod kit Colin1966 Sold 0 03-02-2013 07:40 PM
Brand new SE 204 cam & adjustable pushrod kit Colin1966 Sold 1 01-08-2013 07:11 PM
