2013 RGC ping after dyno - Road Glide Forums
post #1 of 10 (permalink) Old 10-29-2014, 09:18 AM Thread Starter
I just had the SE 255 cams installed, already had SE A/C, decat headers, rinehart slipons, and SE Racetuner. After the cams the bike was retuned. Runs great and HP around 95 and TQ 103. Bringing the bike home (a 200 mile ride one way) I noticed at interstate speed (75) and running the traditional 3000 rpm that on slight uphills the bike will ping. If you give it the onion it does not ping. Taking it back over to get it retuned this weekend? IS it the AFR or something with timing advance?
emt-p is offline
post #2 of 10 (permalink) Old 10-29-2014, 01:49 PM
moose1's Avatar
When mine did it after cams and the SERT I took it back and the just hooked it back up and changed the afrs at the point where I told them it was pinging it only took a few minutes
2012 FLTRU vivid black
moose1 is offline
post #3 of 10 (permalink) Old 10-29-2014, 03:27 PM Thread Starter
cams
Thanks I hope it doesnt take long really happy with the cams, just cant stand the ping, it sounded more front cylinder too.
emt-p is offline
post #4 of 10 (permalink) Old 10-29-2014, 08:23 PM
harleytuner's Avatar
Sounds like spark knock from what you are describing. The timing is advanced to much.
harleytuner is offline
post #5 of 10 (permalink) Old 10-30-2014, 09:22 AM Thread Starter
retune
so from what both of you are saying I gather that they will not have to run the bike on the dyno, just go in with the computer and tuner and tweak the settings?
emt-p is offline
post #6 of 10 (permalink) Old 10-30-2014, 10:42 AM
hd4cruzin's Avatar
Should just hook up to ECM and tweak the settings. I had the same issue with my TTS and brought it back and they adjusted the timing in that area and all is good now. Took 10 minutes
2012 FLTRX BBP
hd4cruzin is offline
post #7 of 10 (permalink) Old 10-30-2014, 11:04 AM
If they know what they are doing they should be able to just hook it up and pull a couple degrees of timing where your issues are.
post #8 of 10 (permalink) Old 10-31-2014, 12:17 PM Thread Starter
Thanks!!! Will know tomorrow how much they know!
emt-p is offline
post #9 of 10 (permalink) Old 11-11-2014, 10:50 AM
How did it turn out?
post #10 of 10 (permalink) Old 11-12-2014, 09:59 AM Thread Starter
They retarded the timing 2 degrees, and was only able to get it to ping once on a 200 mile ride home. And I was trying pretty hard to get it to ping. Happy with the cams, just wondering if the tune still might be off a bit.
emt-p is offline
2013 RG with ping at WOT cookie114 Engine Related 13 01-14-2016 08:06 AM
TTS MasterTune Map to stop Ping and high heat 2011 RGU? Raiderse ECM/Fuel Management systems 15 05-10-2012 01:52 PM
ping... Ping... PING philmartin *General Road Glide Discussions/Pictures 20 07-25-2011 09:10 PM
Ping and Stutter whispanic Troubleshooting for Road Glides 10 05-23-2011 11:21 AM
Heard a "PING!" when riding today okcdoughboy *General Road Glide Discussions/Pictures 26 05-06-2011 11:03 AM
