Disappointed in Dyno Results - Road Glide Forums
post #1 of 31 (permalink) Old 11-23-2014, 06:43 PM Thread Starter
I finally got around to install the exhaust on the '15 CVORGU, so I had my dealer put in a SERT and Dyno it; results 92hp / 108tq. The exhaust I have is CFRs with S&S Power True Duals. I've ran CFRs on my last 3-4 bikes, but this is my 1st experience with S&S; normally run V&H Dresser Duals with the CRFs. Anyway, I'm seeing '15 103s with Stage 1 get this kind of numbers. Additionally, I'm not crazy about the sound of this combo as I think the H-crossover muffles the sound and is not as loud as with V&H dresser duals. I know I loose HP/Tq with CFRs, but I was expecting better numbers; even the HD folks that tuned it was not impressed with the S&S headers. Guess I'll just order some dresser duals, get it dyno'd again, and put these S&S up for sale.
2016 CVO Road Glide
SMSgt B is offline
post #2 of 31 (permalink) Old 11-23-2014, 07:26 PM
jack6hd's Avatar
A good 2-1 will give you some good numbers. You can run a ghost pipe if that's the look you like.
2015 FXDL 2nd best HD on road
jack6hd is offline
post #3 of 31 (permalink) Old 11-23-2014, 08:03 PM
easyrider9809's Avatar
Did you dyno it before you changed out your exhaust?
easyrider9809 is offline
post #4 of 31 (permalink) Old 11-23-2014, 08:26 PM Thread Starter
I agree and I'll have to look at some with ghost pipes, but I have to get over the some personal hurdles with the sound of 2-1s.
Unfortunately I didn't
2016 CVO Road Glide
SMSgt B is offline
post #5 of 31 (permalink) Old 11-23-2014, 08:41 PM
hook's Avatar
CFRs are tough to tune. How much confidence do you have in the person doing the tune?
2011 RGU
hook is offline
post #6 of 31 (permalink) Old 11-23-2014, 09:21 PM Thread Starter
Both the Service Manager and tuner are real good friends of mine, so my confidence is high.
BTW: Here were the numbers from my last CVO (2010 Ultra running CFRs, V&H dresser duals, and ventilator intake:
95.9 HP and 122.2 Torque.
This is what I was expecting to be around.
2016 CVO Road Glide
SMSgt B is offline
post #7 of 31 (permalink) Old 11-23-2014, 10:12 PM
Desertwndrr's Avatar
What mods have you installed in the bike? Cams?
Desertwndrr is offline
post #8 of 31 (permalink) Old 11-23-2014, 10:40 PM
hd4cruzin's Avatar
I'm running second generation CFR's with Fulsac 2-1-2 and TTS on a 12' 103.
#'s are 89HP/110TQ
I would think you would have better #'s.
2012 FLTRX BBP
hd4cruzin is offline
post #9 of 31 (permalink) Old 11-24-2014, 12:09 AM
Craigmier's Avatar
for reference I have a 2013 RG Custom with VH power duals headers and CFR mufflers, SE heavy breather, SE 255 cams ( I believe those are the cams still on 15 CVOs, they were on previous touring CVOs) and at 5,280 feet elevation in Denver it put down 80 hp 101 tq. The before and after graphs is huge and much smoother, power comes on much sooner and stays on later. Your numbers dont seem too bad for your setup. I do think different headers would get you a few more ponies on the dyno but you may not even feel that when riding so not sure I'de spend the money to swap it out. Also remember every dyno is different so the gain from before the tune and after is the main thing. If you look at the dyno graphs Fuel Moto posts on pre 2015 sharks with stage 1, or stage 2, or even 107 kits you will be amazed. I think their dyno reads a lil happy if you know what I mean. Lastly yes you will leave a few ponies on the table with CFR's but are the best sounding pipes
'13 FLTRX - Big Blue Pearl - 16" Carlini Gangster Apes - V&H Power Dual Headers - CFR's - SE255 cams - SE Billet Cam Plate w/High Flow Oil Pump - SE Billet A/C - SERT - Dyno Tune - Daymakers - LRB Carbon Black Rotors - Progressive Suspension - H-D Vented Lowers - Bitchin Stitchin Custom Seat - Rockford Amp - Infinity 6.5's - GADS
Craigmier is offline
post #10 of 31 (permalink) Old 11-24-2014, 08:10 AM
aceman2101's Avatar
You really should check out the Wild Things Power Cell/ Crusher Mellow exhaust. With that combo im making 110TQ/100 HP with just a mild cam and a tune.
aceman2101 is offline
Disappointed Dyno numbers on cam build Skull Engine Related 43 01-22-2016 07:48 PM
Disappointed on the dyno results on my stage IV ironmark Engine Related 24 05-10-2013 12:10 PM
Dyno results ichiban Dyno Results 30 04-13-2012 08:53 AM
Any dyno results with different exhaust? MichiganRider Intake and Exhaust 4 02-26-2012 07:56 AM
RGU Stage One Dyno number results ichiban Intake and Exhaust 5 07-03-2011 12:36 PM
