Dyno - Road Glide Forums
post #1 of 3 (permalink) Old 12-14-2014, 07:28 PM Thread Starter
bulldog68's Avatar
Dyno
If you dyno a motorcycle on a trike dyno ( larger drum ).... Will the numbers be lower than if ran on a regular size dyno ? Thanks
bulldog68 is offline
post #2 of 3 (permalink) Old 12-14-2014, 09:19 PM
tdkkart's Avatar
As long as the dyno software knows what size the drum is the HP should come the same, no matter what size the drum is.
tdkkart is offline
post #3 of 3 (permalink) Old 12-14-2014, 10:02 PM Thread Starter
bulldog68's Avatar
Ok, thanks !
Dealership is not authorized to dyno 2011s??? Gadgetech *General Road Glide Discussions/Pictures 22 12-29-2010 10:40 AM
Good Dyno Tuner in Denver? RockyMtnRG *General Road Glide Discussions/Pictures 7 12-03-2010 10:28 AM
Dyno is done. thunderhorse *General Road Glide Discussions/Pictures 2 06-29-2010 03:41 PM
Dyno Run from Direct Link Install Shrug ECM/Fuel Management systems 6 06-07-2010 09:32 AM
Dyno run On You Tube pte359 *General Road Glide Discussions/Pictures 5 05-21-2010 07:48 PM
