2012 FLTRX 254e Dyno Chart - Road Glide Forums
post #1 of 38 (permalink) Old 05-23-2012, 05:51 PM Thread Starter
scooterroid's Avatar
2012 FLTRX, SE 254e cams, SE Heavy Breather, SE Pro Tuner, Vance & Hines Big Radius
Dyno tune and install by local HD dealership
Scoots
scooterroid is offline
post #2 of 38 (permalink) Old 05-23-2012, 07:54 PM
you should be pretty pleased with that
post #3 of 38 (permalink) Old 05-23-2012, 08:03 PM
Stray Mutt's Avatar
Any idea what the faint line is that maxes out at about 86 hp ( or is that 96 ft-lbs torque?) at 4K rpm? It's kinda flat at 2700 to 4000 or so, then tails off as the rpms increase.
Stray Mutt is offline
post #4 of 38 (permalink) Old 05-23-2012, 10:37 PM Thread Starter
from top:
1st line is final tune torque
2nd line is 1st run torque
3rd line is final tune hp
4th line is 1st run hp
dyno chart is SAE
Not happy with with #'s but I'm OK with them. I suspect the dyno tech at my HD shop is not that experienced, all new faces there. My dyno tune was part of the deal when I bought my bike in March so it had to be done there. I called Doc and wanted to have him tune it but he won't touch a SE Pro Tuner. Rideabilty has improved, definitely can tell the difference in performance and I'm waiting to see if gas mileage is good.
Happy would be 100hp/100tq. Only got a 4hp increase from cam install. I'm probably losing some tq because of my pipes but I've had Thunderheaders the past 15 yrs and I wanted something different on this bike, something purty.
Scoots
post #5 of 38 (permalink) Old 05-23-2012, 11:09 PM
Stray Mutt's Avatar
Ah, now that I'm on the Mac I can make out the final torque curve much better, and the first one wasn't even visible on my other crappy monitor. Yeah, seems like you'd expect a little more than a 4 hp bump after all of that. Hope that mpg is better, but then again them V&H pipes are purty!
post #6 of 38 (permalink) Old 05-26-2012, 08:49 AM
hdxbones's Avatar
Did they work on the ignition timing at all? The timing in the 254e 'canned map' seemed a little lazy for my bike.
Ridin' Roadglides before they were cool.......
hdxbones is offline
post #7 of 38 (permalink) Old 05-26-2012, 08:58 AM
JJSW1283's Avatar
Those pipes are killin you.
JJSW1283 is offline
post #8 of 38 (permalink) Old 05-26-2012, 09:43 AM
petew's Avatar
I have a 2011 RGC/103 with the upgrades listed below, installed... Here is the paper for my tune after the install. It had been running on a canned map for a couple of months or so and although it was running sooo much better than stock, with a tune there could be better performance. Here's the result of dyno tune from HDHD
SE 255's
SE Ventilator AC
SE Tuner
V&H Power Duals
V&H High Output Slipons
2011 RGC
SE RaceTuner
SE Ventilator AC
SE 255's
V&H Power Duals
V&H Hi-Output Slip-Ons
93 HP 109 TQ
petew is offline
post #9 of 38 (permalink) Old 05-26-2012, 09:49 AM
jimmyray11349's Avatar
i am no expert but u should get better numbers with a 103
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #10 of 38 (permalink) Old 05-26-2012, 11:53 AM Thread Starter
I'm no expert either but I do read and research the forums and hang out at some of the dyno tuners whenever I'm in Daytona. Also had a short conversation w/ Doc before I had cams installed and dyno'd.
I figure good pipes are good for ~5hp so that leaves me still missing ~5hp. I think a 103" motor w/ cams, breather, pipes and dyno tune should be low to mid 90's for hp and +100 for tq. I have no idea if or what the HD techs did as far as the dyno tune. A dyno tune can take 4-6 hrs to perform to get it right and produce a custom map. I doubt that much time and effort was put forth on my bike. As far as gas mileage I'm at 1/2 tank showing 100 miles on trip meter. That ain't good but I'll wait to pass judgement on that when I refill the tank. I still have a little throttle lag that I don't like but this is my 1st TBW bike. That being said there isn't much I can do at this point except mull it over and get some of your opinions and comments. Thx.
Also, there is a difference in STD vs SAE dyno charts as some of you probably know.
Scoots
New Dyno Chart page Fuel Moto website fuelmoto Fuel Moto 1 12-14-2015 12:42 PM
254e dyno on 103 RoadGlideGoat Engine Related 6 03-28-2014 11:13 AM
Pls help me understand my dyno chart!!!! CHI_TOWN Dyno Results 8 04-27-2013 01:00 AM
2012 RGU Dyno Chart Joel Daniels ECM/Fuel Management systems 1 04-10-2012 02:51 PM
Wood TW-777 cams, jackpot exhaust dyno chart tkunk Engine Related 19 03-11-2012 08:35 PM
