Another 15 stage 1 dyno 94/117 - Road Glide Forums
post #1 of 13 (permalink) Old 01-07-2015, 06:58 AM Thread Starter
So I finally got my 15 in for exhaust intake and a custom tune at my local shop. It made far more than I expected but I've never seen such a thorough dyno. Front and rear cylinder tuned individually then as a whole. With D&d fat cat, highflo intake and tts mastertune it made 94/117. And before it's asked, it was SAE on a superflo cycledyn.
mpgonthehill is offline
post #2 of 13 (permalink) Old 01-08-2015, 10:05 PM
bulldog68's Avatar
Nice ! Our local dyno is on the low side, but has a very good operator. You made more torque than my stage 4.
bulldog68 is offline
post #3 of 13 (permalink) Old 01-08-2015, 10:46 PM
hd4cruzin's Avatar
Nice numbers. Bet your happy!
2012 FLTRX BBP
hd4cruzin is offline
post #4 of 13 (permalink) Old 01-24-2015, 04:34 PM
FFZHD's Avatar
Cams or no Cams ????
2015 RGS- 26" Mad Digger, Woods 777, D&D 2-1, PV2, RSD AC: 101/109, TopShop Black Death kit, lotz of gloss BLK PC
Ride it like you STOLE IT
FFZHD is offline
post #5 of 13 (permalink) Old 02-11-2015, 04:39 PM Thread Starter
Stock Cams for now. Looking at a build in the next year
post #6 of 13 (permalink) Old 02-11-2015, 05:13 PM
Ohiobellboy's Avatar
Numbers are the same as my '11 I had. Same exhaust as yours and mine was a 110.
A.K.A OBB
Ohiobellboy is offline
post #7 of 13 (permalink) Old 02-11-2015, 09:11 PM
FFZHD's Avatar
WOW nice numbers!!
What baffle do you have in the fat cat??
Going to be using the same set up but with Woods cams and PV2, its going up to FM for Jamie to work his magic in 2 weeks.
Thanks
FFZHD is offline
post #8 of 13 (permalink) Old 02-12-2015, 05:50 AM
2015 stock with just pipe and air cleaner tune?
Stock 103 or stock 110CVO?
Super flow Dyno has a tendency to read about 8/10% higher than a Dyno jet.
Those are the kind of numbers we see with cams and exhaust and TQ just a little lower. Like 94/96 HP 108/112 tq avg.
But as long as your happy with tune bike runs great that's what matters the most.
Please don't take this in the wrong way. All the bikes we have tuned stock with good exhaust have never seen numbers like that stock unless it's a CVO 110
Thanks
FD
DragoBikeWorks is offline
post #9 of 13 (permalink) Old 02-21-2015, 07:08 PM
harleytuner's Avatar
It's the SuperFlow dyno.
OP, i'm in Fredericksburg, if you want you can bring it down and put it on my DynoJet if you're curious to what it makes on one. No charge.
harleytuner is offline
post #10 of 13 (permalink) Old 03-03-2015, 07:04 AM
Thanks
FD
I have to agree, if these were the numbers you get with just a stage 1 then nobody would bother with the expense of adding aftermarket cams... Just saying. But whatever the reason, as long as you're happy with the way the bike runs that's all that matters.
Berms is offline
2018 CVO 117" dyno testing Fuel Moto fuelmoto Dyno Results 4 11-14-2017 02:45 PM
CVO 117 dyno help ClinesSelect Dyno Results 11 02-12-2017 08:35 PM
117" Harley kit dyno results MTrider Dyno Results 9 05-16-2016 10:24 AM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 09:31 AM
Detachable backrest and luggage rack '94-'08 DarbinCo Classifieds Archive (3 months old+) 0 04-29-2012 11:28 AM
