96 in Cam choice - Road Glide Forums
post #1 of 7 (permalink) Old 02-17-2015, 08:49 AM Thread Starter
96 in Cam choice
Finally taking the 2010 rg custom in for cams, already has PCV and rhinehart 2n1 with high flow AC. Which would be the the better choice in cams,andrews 48 or woods 222. I ride 90/10 one up and like to get it occasionaly. My dyno read 80/91 after putting on the rhineharts. Do you thiink I will pick up much more. thanks duane5157
The only easy day was yesterday
2010 FLTRX
Rhinehart 2n1
Big Sucker
PC Vision
Sig 220
duane5157 is offline
post #2 of 7 (permalink) Old 02-17-2015, 09:22 AM
I run the Woods TW 222 cams and they are a great low end/mid range torque cams, the torque comes on early and holds real well which works great for touring model bikes.
The Woods cam will produce more torque sooner then the Andrews will according to specs.
Both are good cams and the Woods may cost a little more but they are worth it IMO.
post #3 of 7 (permalink) Old 02-18-2015, 07:12 PM
Road dawg's Avatar
+1 on the woods 222 cams solid choice, a better alternative than the Andrews 48 IMO is the feuling 525 which I personally run, bothe are great torque cams, the way to go.
Road dawg is offline
post #4 of 7 (permalink) Old 02-18-2015, 07:27 PM
PBSTN's Avatar
I am running Andrews 48's. Runs great. Plenty of low end torque.
2001 FLHR-Traded. 2010 FLTRX-Sold.
2010 FLHR
2003 FLHRSEI2
PBSTN is offline
post #5 of 7 (permalink) Old 02-18-2015, 08:38 PM
I ran the 222's in my 08 SG and loved them. They made a big difference, especially riding 2up.
90b4032 is offline
post #6 of 7 (permalink) Old 02-19-2015, 02:42 AM
SLOglide's Avatar
I have the 48's. I noticed (seat of the pants dyno) better all around torque and the power stays with you to a higher RPM compared to stock. I realize comparing to stock isn't saying much but it's all I have to go on. They are a good cam for the everyday rider who isn't interested in leaving rubber at every stop sign.
John not in Saudi any more!!, mortgage in Cal.
2009 Road Glide; HoboCoastie's tank lift, Andrews 48H cams, TTS, Progressive 940's, a bit of chrome.
SLOglide is offline
post #7 of 7 (permalink) Old 02-19-2015, 04:42 PM
If your not going to do any other work the Tman 555 torqster is a great bolt in cam. You have the perfect opportunity to bore and go to a 107 with 10:5 to 1 compression with the tman 555 cams. The 96 is a slug with just cams due to the low compression of the stock engine.
sporacer is offline
2016 103" cam choice Troda Engine Related 16 07-05-2016 05:52 AM
twin cam 96" heads/103" cylinders and pistons JKRSDETROIT Parts for Sale 2 05-18-2013 08:03 PM
Cam choice craigv65 Engine Related 44 04-17-2012 04:09 AM
Cam & heads on 2010 96" tc - need advice Rumblepotomus Engine Related 23 10-03-2011 04:48 PM
cam choice jimbob Engine Related 14 11-17-2010 07:52 AM
