15 Road Glide Wood TW-777, D&D Fatcat 2/1 - Road Glide Forums
post #1 of 13 (permalink) Old 03-04-2015, 01:57 PM Thread Starter
EFI tuning and Exhaust Expert
fuelmoto's Avatar
installed Wood TW-777 cams in a 2015 Road Glide yesterday
From our Facebook news feeds https://www.facebook.com/FuelMoto
+23Hp/15Tq; Fred S. brought us is stock 2015 Road Glide and we installed Wood TW-777 cams, RSD air cleaner, D&D Fatcat 2/1 exhaust, and dyno tuned it with Dynojet Power Vision
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #2 of 13 (permalink) Old 03-04-2015, 02:18 PM
HellInABucket's Avatar
Interesting. Where's that low end TQ dip I always see with a Fat Cat (and most 2-1)?
Maybe its only a matter of the skill of the tuner, then! Hmmmm....
HellInABucket is offline
post #3 of 13 (permalink) Old 03-04-2015, 05:06 PM
Q-Hog's Avatar
Can you advise How does it compare to Woods 555?
Q-Hog is offline
post #4 of 13 (permalink) Old 03-04-2015, 05:12 PM
torqu's Avatar
Just seen the spec sheet on the 222 with the same setup. Q it made more torque.
torqu is offline
post #5 of 13 (permalink) Old 03-04-2015, 06:45 PM
Q-Hog's Avatar
Torque,.. I also see that Frank's new cam shows good numbers too. Some many choices.
Thanks for sharing the info Fuelmoto.
Q-Hog is offline
post #6 of 13 (permalink) Old 03-04-2015, 07:13 PM
RichieRich's Avatar
777 probably would have looked even better with a little compression bump
2013 BBP FLTRX
RichieRich is offline
post #7 of 13 (permalink) Old 03-04-2015, 07:51 PM
bulldog68's Avatar
Which baffle ? And was the cam straight up or advanced 4 degrees ? Thanks. Looks great !
bulldog68 is offline
post #8 of 13 (permalink) Old 03-04-2015, 09:41 PM
FFZHD's Avatar
Baffle is louvered wrapped, Jamie will have to answer cam ? but pretty sure Itz straight up
next step is bump compression, one step at a time. thats y I did the 777, so i only need to change cam once. I'm pretty happy with set up, now if the salt and snow would leave, and I could twist the wrist on this thing.
Thanks alot Jamie and the crew at Fuel Moto
2015 RGS- 26" Mad Digger, Woods 777, D&D 2-1, PV2, RSD AC: 101/109, TopShop Black Death kit, lotz of gloss BLK PC
Ride it like you STOLE IT
FFZHD is offline
post #9 of 13 (permalink) Old 03-04-2015, 09:55 PM
Q-Hog's Avatar
Looks good. Nice job.
Q-Hog is offline
post #10 of 13 (permalink) Old 03-05-2015, 02:31 PM
bulldog68's Avatar
Looks good ! Louvered baffle helps that torque below 3500
15 Road Glide Wood TW-222 cams, D&D Fatcat 2/1 fuelmoto Dyno Results 6 04-22-2015 05:57 PM
2012 103" Wood TW-777 cams FM Level B Heads fuelmoto Dyno Results 6 12-16-2013 01:07 PM
Wood TW-777 cams, jackpot exhaust dyno chart tkunk Engine Related 19 03-11-2012 07:35 PM
2012 Touring 103" Jackpot exh Wood TW-777 Cams fuelmoto Dyno Results 2 11-24-2011 11:45 PM
2012 103" Touring Testing Wood TW-777 Cams fuelmoto Fuel Moto 6 10-24-2011 03:50 PM
