stage 4 screaming eagle dyno - Road Glide Forums
post #1 of 13 (permalink) Old 07-14-2012, 08:53 AM Thread Starter
IranAround's Avatar
115 hp and 112 tq got some good numbers and man does she run
15 FLTRXS Black Denim
13 FLTRX Big Blue Pearl se IV sold
11 FLTRX se stage lV (TOTALED)
IranAround is offline
post #2 of 13 (permalink) Old 07-14-2012, 04:57 PM
I bet the "seat of the pants dyno" is even better, have fun and ride safe.
post #3 of 13 (permalink) Old 07-15-2012, 01:33 AM Thread Starter
IranAround's Avatar
By far it is my friend and it runs so much cooler
post #4 of 13 (permalink) Old 07-18-2012, 11:15 PM
Did your kit have 260 cams or the 259E?
rc_chico is offline
post #5 of 13 (permalink) Old 07-21-2012, 09:34 PM Thread Starter
IranAround's Avatar
I have the 259e which ones are are better ?
post #6 of 13 (permalink) Old 07-25-2012, 08:57 AM
picksterRG's Avatar
I am having the SE 4 kit installed now, hope my numbers are similar - the ne kits are 259 cams, they are supposed to have a better torque curve than the 260 cams from previous kits and the heads are different from before as well - the SE 4 street legal kits do not come with injectors or cylinders and don't use the SERT from what I understand. Once I get mine broken in I will post my dyno
picksterRG is offline
post #7 of 13 (permalink) Old 07-25-2012, 09:33 AM Thread Starter
IranAround's Avatar
The tech that did mine said he could have gotten more power but it would have cut in to the reliability of the bike but you should see similar numbers
post #8 of 13 (permalink) Old 07-29-2012, 05:43 PM
letsgofast's Avatar
What is involved in the kit that you had installed? I have the 259E and high compression pistions with Rinehart true duals. Mine made 98hp/103 tq. Did you do heads?
letsgofast is offline
post #9 of 13 (permalink) Old 07-29-2012, 08:02 PM Thread Starter
IranAround's Avatar
yeah i did the 110 ported heads too but i did the racing 4 in rinehart true duals and throttle body
post #10 of 13 (permalink) Old 07-31-2012, 07:07 AM
picksterRG's Avatar
I had the SE 103 stage 4 racing kit installed, am still breaking it in now, if you have a 96" motor it is a full top end kit, heads, pistons, cylinders, tb, injectors, clutch spring, 259e cams, SE race tuner, you can see the kit list in the 2012 online race catalog. There is a 49 state street legal version that is for 103 engines, it is basically the same except for cylinders, no injectors, no race tuner, it puts out a little less torque and hp, no cylinders as this kit assumes you don't need them. ACR and oil cooler are separate
Dark Shark dyno: Big Sucker, Pro Pipe & Screaming Eagle Tuner Rasconzo Dyno Results 8 04-16-2015 03:39 PM
Screaming Eagle Stage 1 air cleaner beavis Classifieds Archive (3 months old+) 0 09-29-2012 01:51 PM
Screaming Eagle Stage IV Cam Change gbourdon Engine Related 13 10-13-2011 11:38 AM
screaming eagle stage 1 kit 2bagger Classifieds Archive (3 months old+) 2 06-14-2011 07:39 AM
Stage 1 & Screaming Eagle Exhaust buzzman_45011 Intake and Exhaust 4 05-17-2010 11:12 AM
