Here are 2 pulls we did with the temps being 99/103 deg in our shop.
This is a 2008 Bagger with stock 96 inch motor with PCV and are SCS true duals with 2.05 baffles.
Not bad for true duals and 100 plus temps.....Sae SM5.... Dual WBC
and pulss are 13.1 afr front and rear cylinder.
One is a 4th gear pull is the leeser tq number and pull starts from 2000rpm
One is a 5th gear pull is the higher tq number and pull starts from 2400rpm
