Dragos true duals 2008 stock bagger with 255 cams - Road Glide Forums
post #1 of 1 (permalink) Old 07-17-2012, 12:20 PM Thread Starter
Here are 2 pulls we did with the temps being 99/103 deg in our shop.
This is a 2008 Bagger with stock 96 inch motor with PCV and are SCS true duals with 2.05 baffles.
Not bad for true duals and 100 plus temps.....Sae SM5.... Dual WBC
and pulss are 13.1 afr front and rear cylinder.
One is a 4th gear pull is the leeser tq number and pull starts from 2000rpm
One is a 5th gear pull is the higher tq number and pull starts from 2400rpm
File Type: jpg dragos td 2008 bagger with 96 inch 255 cam pcv.jpg (88.4 KB, 130 views)
DragoBikeWorks is offline
Rush Racing True Duals-up to 2008 Nightrain04 Parts for Sale 0 10-20-2013 04:44 PM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
True definition of true duals? cypress Intake and Exhaust 8 06-23-2012 10:22 PM
Thunderheader true duals/MGS true duals JKRSDETROIT Intake and Exhaust 2 03-26-2012 01:06 PM
2008 True Duals...which ones? ncbeast Intake and Exhaust 23 10-22-2011 10:41 AM
