2015 rgs - Road Glide Forums
post #1 of 6 (permalink) Old 04-18-2015, 09:01 PM Thread Starter
DarkKnight15's Avatar
2015 rgs
Thought I would share my Dyno results for anyone interested in upgrading a new 2015. The base run on the Dyno Sheet are after the cam Install with a generic map.
103" SE Heavy Breather, D and D Fat Cat 2-1, SERT, Woods TW-222 cams.
Max HP = 91.30
Max Torque = 109.02
2015 Road Glide Special -SE Heavy Breather-D and D 2-1 -SERT- TW-222
DarkKnight15 is offline
post #2 of 6 (permalink) Old 04-18-2015, 11:46 PM
Q-Hog's Avatar
Nice....
Q-Hog is offline
post #3 of 6 (permalink) Old 05-25-2015, 01:17 PM
K_Tubb's Avatar
should be a beast once it's tuned.
2015 FLTRXS Vivid black SE Stage1 Air cleaner, Dynojet PCV, R6C 13" holly rollers bars.
IF YOU AIN'T RIDING. IF YOU AIN'T GLIDING.
K_Tubb is offline
post #4 of 6 (permalink) Old 05-30-2015, 07:36 AM
Redbullseye41's Avatar
I just had V&H Power Duals, Vance & Hines Hi Output Duals, Power Commander 5, & Performance Machine Contrast Cut Max HP Air Cleaner put on. I had a them do a Dyno with the1000 mile service. I went from 98.59 Max Torque to 106.40 & 81.19 Max Power to 85.48.
Would like to hear others' results as well.
Redbullseye41 is offline
post #5 of 6 (permalink) Old 06-01-2015, 06:55 PM
FLtroll's Avatar
I'm running stage 1 air cleaner, SE 255 cams, Fuel Moto head pipe with stock CVO mufflers and Harley tuner
90 hp
103 tq
2011 Road Glide Ultra. Merlot Sunglo
FLtroll is offline
post #6 of 6 (permalink) Old 06-29-2015, 03:05 PM
Vance and Hines Big radius
SERT
Heavy breather...
On my 2015 RG....my numbers don't compare to those above.
Avalanche123 is offline
2016 RGS or 2017 RGS? PEZRACER *General Road Glide Discussions/Pictures 11 09-01-2016 02:14 PM
ORD's new scooter 2015 RGS oldredog77 *General Road Glide Discussions/Pictures 30 04-02-2015 09:11 PM
Are the handlebars on the 2015 CVO model the same bars that come on the RG and RGS? Berms *General Road Glide Discussions/Pictures 14 11-29-2014 02:39 PM
Cam shopping for my 2015 RGS hdtwncam88 Engine Related 12 10-09-2014 04:34 AM
The Cure II: My 2015 RGS Sethjamto *General Road Glide Discussions/Pictures 28 09-22-2014 04:51 PM
