2015 Drago's 2 and 580 cam - Road Glide Forums
post #1 of 3 (permalink) Old 04-24-2015, 02:29 PM Thread Starter
Johndeere's Avatar
This is the result of my cam swap. Remember I have not had it tuned yet so this is off the base map for my last set up. I hope more is coming but still a nice increase.
Original set up. 10.5-1 pistons, .030 base gasket, 600 manly springs, ported heads and throttle body, and 259E cam. The pipe has always been Franks 2. This dyno shows just the difference between his cam and a tuned 259E. I hope to see more as I tune.
Johndeere is offline
post #2 of 3 (permalink) Old 04-24-2015, 02:34 PM Thread Starter
Johndeere's Avatar
Better image of sheet.
post #3 of 3 (permalink) Old 04-24-2015, 05:15 PM
tj316's Avatar
That's a nice gain
tj316 is offline
Map for dragos 580 cam--powervision shark attack Map Section 4 08-19-2015 03:54 PM
2012 FLTRX Drago 580 cams, Dragula 2:1 rustyj671 Dyno Results 4 07-02-2015 05:04 PM
2012 Dragos 580 cam, Dragos 2, TTS hd4cruzin Dyno Results 20 05-05-2015 08:26 PM
New Dragula 2 pipe and Dragos 580 bolt in cams DragoBikeWorks Engine Related 16 11-18-2014 11:08 PM
