2011 cvo rgu 124 - Road Glide Forums
post #1 of 12 (permalink) Old 05-12-2015, 07:07 PM Thread Starter
2011 cvo rgu 124
This was my winter project on my 2011 CVO RGU. A full description of the build is posted in the Road Glide Builds section of this forum. I am very pleased with the results. The bike is a screamer everywhere on the power band. A blast to ride!
jwalker793 is offline
post #2 of 12 (permalink) Old 05-12-2015, 07:49 PM
Nice Curves! 'Gotta love those T-Man Cams!
HeatWave is offline
post #3 of 12 (permalink) Old 05-12-2015, 07:57 PM
RGKen's Avatar
Very nice!!!!😀
2018 FLTRXS
RGKen is offline
post #4 of 12 (permalink) Old 05-12-2015, 08:43 PM
madmat's Avatar
Nice!!!
18 RGS Bonneville Salt Pearl
madmat is offline
post #5 of 12 (permalink) Old 05-12-2015, 09:06 PM
Nordic Berserker's Avatar
very nice!
Nordic Berserker is offline
post #6 of 12 (permalink) Old 05-12-2015, 09:49 PM
Desertwndrr's Avatar
That's gettin it done! I bet that is one riot to ride. Great numbers.
Desertwndrr is offline
post #7 of 12 (permalink) Old 05-13-2015, 09:28 AM Thread Starter
I went from the 110 to 113 to 124. Surprisingly, the 124 is really smooth and doesn't generate the heat of the other two engines. You still know you have a 124 between your legs. The responsiveness is unbelievable , especially for a 900+ lb. bike.
post #8 of 12 (permalink) Old 05-13-2015, 01:54 PM
It would be nice if you gave specifics on the build like compression ratio,tb size ,injector size, etc.
sporacer is offline
post #9 of 12 (permalink) Old 05-13-2015, 10:03 PM Thread Starter
Here's the build spec. I posted this on the RG Build section of this forum.
Hyperformance/R&R 124 Short Block w/ CP Pistons, H-Beam rods & Timken 10.74:1
T-Man 590 Cams, Cometic .030 head gaskets
Dan Thayer 3 Stage Oil Pump
S&S Premium High Performance Lifters with HL2T
SE billet cam plate w/ Axtell Oil Bypass and Red Shift Chain Tensioners
Smith Brothers push rods, SE Forged Rocker supports
S&S Non-roller Forged Rocker Arms 1.625 and Billet Tappet Covers
V&H Power Dual Exhaust with Kury Mellow Crusher Mufflers
HPI-58 FBW with 6.2 High Flow Injectors (Ported)
SE Heavy Breather Air Cleaner
Bandit Sportsman Superclutch
Aim/Evolution Heavy Duty Billet Clutch Basket w/ 46T sprocket & 106T ring gear
Cycle Electric Stator and Voltage Regulator
2014 SE Compensator with GMR Compensaver, Hayden Primary Chain Tensioner
Jagg Low Mount 10 Row Oil Cooler w/ K&P Stainless Steel Oil Filter
Fuel Moto Racewires compatible with Delphi adaptive knock retard with Stock Plugs
Jim's Forceflow, Dimple Magnetic Drain Plugs
True Track Front & Rear Stabilizers
Legend Air Suspension (rear) w/ Air Gauge, Progressive Monotube Kit (Front)
George’s Garage Trap Door
Baker Cruise Drive Smooth Shift Kit, Baker 30T Cruise Drive Pulley w/ Jims Mega Nut
Gates Polychain PC-139A Belt
Goodson/AV&V Beehive Spring Set (.600)
110 Heads worked by WFOLarry w/ AV&V 2.100 intake and 1.650 exhaust valves w/ Bronze Guides.
Power Vision
post #10 of 12 (permalink) Old 05-13-2015, 10:57 PM
Perlinal's Avatar
My 124 just came in last week. Looking forward to it..
Perlinal is offline
124 s&s / 120r to 124 Vinny Engine Related 80 05-17-2015 11:58 PM
2011 CVO RGU 124 Build jwalker793 Road Glide Builds-Document your builds HERE --NEW 2 05-13-2015 09:16 AM
Dragos 124 engine/S&S 124 JKRSDETROIT Engine Related 41 03-14-2015 10:50 AM
Dyno results tman 124 2013 cvo sporacer Dyno Results 11 09-25-2014 04:28 PM
124 Crate motor in 2011 karlrockdrain Dyno Results 2 02-04-2014 12:39 PM
