'12 FLTRX - Dragos 1.5 heads, 580 cams, Dragula 2, .040 head gasket - Road Glide Forums
post #1 of 9 (permalink) Old 06-12-2015, 11:09 AM Thread Starter
pulls like a beast and am very pleased with the build. doesn't run too hot and handles great. tons of power.
still having a bit of a rough idle on warm-up but once it's at temp is fine. just need to tweak TTS a bit.
also trying to find an annoying chirp that started after build (it's not the rubber exhaust hanger). i don't think it's a lifter...well i hope it's not a lifter. when you're back at the pipe it sounds like it's coming from inside the pipe. when you're standing next to the engine it sounds like it is coming from underneath the engine in the middle. no head leaks, intake leaks, or exhaust leaks. it mostly goes away once the engine heats up. any ideas?
2012 FLTRX - stage 1.5 headwork, dragos 580 cams, 10.25 comp, FM stage 1 intake, dragula 2, TTS, 13" windvest, 14" evil apes, JRI 12" shocks, progressive monotubes, hertz and alpine, hawg wired amp, custom LED gauges, custom dynamics LED signals, lots o' powder coat
San Diego, CA
modot66 is offline
post #2 of 9 (permalink) Old 06-12-2015, 11:15 AM
hd4cruzin's Avatar
Nice looking Dyno. Did Geoff do the install as well? Haven't seen him in a while. Looks like a fun ride.
I have the 580 cams in my 2012 with TTS and runs great. It does run a little rough when first started, but after 1-2 minutes. it's fine
2012 FLTRX BBP
hd4cruzin is offline
post #3 of 9 (permalink) Old 06-12-2015, 11:29 AM Thread Starter
no, geoff just tuned it for me. interesting to hear that others have a little rough warmup on these cams as well. not a huge deal to me as they are bad-ass cams! i'm sure once i run some datamaster logs i can smooth it out.
San Diego, CA
modot66 is offline
post #4 of 9 (permalink) Old 06-12-2015, 05:57 PM
rustyj671's Avatar
A buddy of mine had a similar noise, same location and got better when the engine was hot.
It was an O2 sensor that had come loose. You might want to at least check them.
'12 FLTRX ==> PV w/ TT, PM Super Gas A/C, Dragos 580 cams, Fullsac DX pipe and 2" baffles in stock muffs, 18" Badseed bars, Custom Dynamics lighting, Dunlop AE tires, Aquatic Audio, JL Audio amp, Polk speakers, Progressive Monotubes, Alloy Art Stabilizer and Cush Drive, GMR Compensaver on SE compensator, Rush Cycle Pedic seat....all thanks to this forum.
rustyj671 is offline
post #5 of 9 (permalink) Old 06-12-2015, 06:00 PM
rustyj671's Avatar
Also,
I have the 580 cams as well and still not dynoed yet. Went to the Grand Canyon a month ago and it ran like crap at elevation. Spit, sputter, cough....lol you get the picture. Back here at sea level, just a little sputtering when cold is all.
post #6 of 9 (permalink) Old 06-12-2015, 09:02 PM
hogboy57's Avatar
i have same set up. had tts and switched to thundermax tuner
2017 laguna orange road glide special c&c solo seat xm radio harleys 18" black blade rims cyclesmith bananaboards chrome front end progressive ultra low rear shocks dragons slip on mufflers painted inner fairing DD ghost chrome handlebars 9" black windvest windshield coo rear fender
hogboy57 is offline
post #7 of 9 (permalink) Old 06-13-2015, 10:57 PM Thread Starter
right on thanks for the suggestion, i'll go check it tomorrow and see if it's loose
San Diego, CA
modot66 is offline
post #8 of 9 (permalink) Old 07-25-2015, 09:26 AM
That looks great!!!! And thankyou Enjoy!!!!!
DragoBikeWorks is offline
post #9 of 9 (permalink) Old 08-21-2015, 08:56 PM
turbochrisb's Avatar
Nice! Last time I was in Cycle Doctor, I asked about Dragos products and the owner said he'd never heard of em....bet he'll remember now!
turbochrisb is offline
Dragula 2 and Dragos 580 bolt in cams DragoBikeWorks Dyno Results 7 03-27-2018 07:54 AM
2012 FLTRX Drago 580 cams, Dragula 2:1 rustyj671 Dyno Results 4 07-02-2015 05:04 PM
Dragos 580 Cams and Dragula 2-1 rustyj671 Engine Related 3 03-17-2015 09:19 PM
New Dragula 2 pipe and Dragos 580 bolt in cams DragoBikeWorks Engine Related 16 11-18-2014 11:08 PM
