2015 Limited stage 1 Dyno results - Road Glide Forums
post #1 of 4 (permalink) Old 07-02-2015, 09:54 AM Thread Starter
dynoguymn's Avatar
I just got done with a 2015 twin cooled 103" stage 1. A real decent result. I tried to tune the dip at 3700 out but it wasn't budging. I believe it was a exhaust pulse. I adjusted both fuel and timing. It's what it is...
dynoguymn is offline
post #2 of 4 (permalink) Old 07-02-2015, 10:42 AM
Scoop's Avatar
What was used for the tune? Was this the SERPT? Do you have a file you can share with the air/fuel ratios? Just curious. The torque looks good, does it run cooler too?
Scoop
2011 FLTRU Fullsac Sportpipe, SE Breather/air cleaner, SEPRT Smart-tune, Corbin, Madstad 13", Gold Top Fork Emulators & Springs & JRI B shocks. 2003 XLHS
Scoop is offline
post #3 of 4 (permalink) Old 07-02-2015, 11:11 AM Thread Starter
dynoguymn's Avatar
Yes, it was the Sepst. Every bike responds to tunes differently. You could have the exact same year and model and the exact same components installed but the tune won't act the same.
This bike ran between 220-240 degrees on the Dyno. On the road it was about 190 but is was only 80 outside.
post #4 of 4 (permalink) Old 07-02-2015, 11:13 AM Thread Starter
dynoguymn's Avatar
Just realized I put TTS Mastertune on the sheet. That's our preferred tuner... Habit I guess
It was a Sepst though
'16 RG - Stage 1 Dyno Results SteadyEddie Dyno Results 28 07-29-2016 02:46 PM
2015 RG Stage One Dyno results Avalanche123 Dyno Results 23 07-31-2015 07:29 AM
13 RCG Stage 1 Dyno results lvyper876 Dyno Results 6 03-29-2015 04:01 PM
Disappointed on the dyno results on my stage IV ironmark Engine Related 24 05-10-2013 12:10 PM
RGU Stage One Dyno number results ichiban Intake and Exhaust 5 07-03-2011 12:36 PM
