2012 FLTRX Drago 580 cams, Dragula 2:1 - Road Glide Forums
post #1 of 5 (permalink) Old 07-02-2015, 03:35 PM Thread Starter
rustyj671's Avatar
This is the final 5th gear pull using WinPep8. About 90 degrees and about 50% humidity. Barometric pressure 29.98
92hp/101tq
Any thoughts as to why it's 10 under what I expected? The tech said it was because WinPep8 is more sensitive to the actual conditions, uses MAP as opposed to throttle position and not as able to be manipulated as previous versions.
All of the other runs were in 4th gear and about 2 points lower in both hp and tq. I asked for a 5th gear pull specifically to be more comparable to those I've seen here.
Last edited by rustyj671; 07-02-2015 at 04:08 PM. Reason: couldn't upload pic from my phone
rustyj671 is offline
post #2 of 5 (permalink) Old 07-02-2015, 03:52 PM
dynoguymn's Avatar
It needs to be tuned. Your AFR between cylinders is off. It does have a nice smooth power curve though. Don't put too much into Dyno numbers. That's an expensive path to take
dynoguymn is offline
post #3 of 5 (permalink) Old 07-02-2015, 04:32 PM
pat123's Avatar
Find a new tuner! That's low
pat123 is offline
post #4 of 5 (permalink) Old 07-02-2015, 04:33 PM
Who tuned the bike?
Your afr table looks to be all over.
But it hard to tell from pic it's blurry.
Here is one few months ago
5th gear pull
But as you can see there are many Dyno sheets on this forum from other shops.
One thing I can say is that the heat and humidity is not helping you either.
DragoBikeWorks is offline
post #5 of 5 (permalink) Old 07-02-2015, 05:04 PM Thread Starter
rustyj671's Avatar
Frank, I just emailed you the pic directly from my phone.
You should have seen the AFRs when he started. They were WAY all over the place. I had taken Pat123s tune, put it in the bike and autotuned a couple of times (for at least 1 hour each).
I don't know if he started with Pat's tune or the autotune.
'12 FLTRX ==> PV w/ TT, PM Super Gas A/C, Dragos 580 cams, Fullsac DX pipe and 2" baffles in stock muffs, 18" Badseed bars, Custom Dynamics lighting, Dunlop AE tires, Aquatic Audio, JL Audio amp, Polk speakers, Progressive Monotubes, Alloy Art Stabilizer and Cush Drive, GMR Compensaver on SE compensator, Rush Cycle Pedic seat....all thanks to this forum.
Dragula 2 and Dragos 580 bolt in cams DragoBikeWorks Dyno Results 7 03-27-2018 07:54 AM
'12 FLTRX - Dragos 1.5 heads, 580 cams, Dragula 2, .040 head gasket modot66 Dyno Results 8 08-21-2015 08:56 PM
2015 Drago's 2 and 580 cam Johndeere Dyno Results 2 04-24-2015 05:15 PM
Dragos 580 Cams and Dragula 2-1 rustyj671 Engine Related 3 03-17-2015 09:19 PM
New Dragula 2 pipe and Dragos 580 bolt in cams DragoBikeWorks Engine Related 16 11-18-2014 11:08 PM
