Dyno Results - Road Glide Forums
post #1 of 5 (permalink) Old 09-11-2012, 09:11 AM Thread Starter
Radioactive's Avatar
Dyno Results
Finally got it dyno tuned. First sheet is of a diagnostic dyno last fall for pinging. Still had the stock 2 into 1 on it then. Tech has not been to training yet and didn't have much experience. He also didn't know how to print the AFR's. But for $90 you get what you pay for.
I'm thinking of adding a TTS Mastertune and taking it to a master tuner but what do you guys think?
103" Big Bore kit, SE 259 cams, SE 10.5:1 pistons, SE A/C and SERT at delivery March 2010. Changed to a Arlen Ness Derby Sucker 2011.
Dragula 2 into 1 with 2.5" baffle Spring 2012.
Initial Run (Stock 2 into 1 exhaust)
Last Run (Dragula 2 into 1 only addition)
Radioactive is offline
post #2 of 5 (permalink) Old 09-11-2012, 09:15 AM
The second link is with the new exhaust right...
I thinking it could a little better but what do you guys think?
103" Big Bore kit, SE 259 cams, SE 10.5:1 pistons, Arlen Ness Derby Sucker, SERT and a Dragula 2 into 1 with 2.5" baffle.
http://s1118.photobucket.com/albums/...t=92D8696E.jpg
http://s1118.photobucket.com/albums/...t=C49D46A7.jpg
DragoBikeWorks is offline
post #3 of 5 (permalink) Old 09-11-2012, 09:45 AM Thread Starter
Hey Frank,
This is the one I sent you last week and yes, the bottom is with the Dragula. Ment to label them from the start.
post #4 of 5 (permalink) Old 09-11-2012, 11:38 AM
Thats what I thought.
Hey Frank,
post #5 of 5 (permalink) Old 09-13-2012, 04:50 AM Thread Starter
Might help if I added the images correctly.
Dyno results ichiban Dyno Results 30 04-13-2012 09:53 AM
Dyno Results! brhodea *General Road Glide Discussions/Pictures 2 03-05-2012 10:13 AM
Stock Dyno results 1st Sgt ECM/Fuel Management systems 17 03-03-2012 05:12 AM
Any dyno results with different exhaust? MichiganRider Intake and Exhaust 4 02-26-2012 08:56 AM
RGU Stage One Dyno number results ichiban Intake and Exhaust 5 07-03-2011 01:36 PM
