Not happy - Road Glide Forums
 17Likes
post #1 of 38 (permalink) Old 08-10-2015, 11:09 AM Thread Starter
SMOKENJOE's Avatar
Not happy
Was at a bar where the had a dyno there they put my bike on and it made
109.9 HP and 115.37 Torque I was hopping for a little more because the afr in the front cyclinder is very high I was told my controller was bad the heat that day at time of dyno was 109.84F 7% humidity tried to load dyno sheet but failed many times
SMOKENJOE is offline
post #2 of 38 (permalink) Old 08-10-2015, 01:21 PM
09Sharknose's Avatar
What kind of numbers were you expecting and why?
09Sharknose is offline
post #3 of 38 (permalink) Old 08-10-2015, 01:33 PM Thread Starter
SMOKENJOE's Avatar
Same exact build as mine produced 121.16 hp and 124.57 tq I would have thought I would be around 118hp and 120 tq but as i said my front cylinder afr was about 19 instead of 13.3 like I programed and I am sure the heat did not help
post #4 of 38 (permalink) Old 08-10-2015, 02:20 PM
PFWiz's Avatar
If it was hot and you know your AFR was off then why are you unhappy? On cooler day with the proper AFR don't you expect to do noticeably better?
PFWiz is offline
post #5 of 38 (permalink) Old 08-10-2015, 02:54 PM
pat123's Avatar
I can't say I didn't see this one coming. Get that tmax tuned or find a real tuner.
Regardless on how thundermax promotes their tuner it needs to be tuned to get the most power out of it. Ignition Timing is everything.
Tmax isn't a plug and play unit. Just a bunch of BS
pat123 is offline
post #6 of 38 (permalink) Old 08-10-2015, 03:14 PM
PGR
PGR's Avatar
Maybe you could try a dyno that's not located at a bar
Ron..........................
PGR is offline
post #7 of 38 (permalink) Old 08-10-2015, 03:51 PM
tdkkart's Avatar
The 1st thing you'll learn about dynos is that the last liar always wins.
The 2nd thing you'll learn is that they're ALL different.
The 3rd thing you'll learn is that every engine is different, and every tune is different, every set of pipes is different. Getting the same numbers as your buddy even from the same tuner is a crap shoot, and if it the 2 engines were built by different builders it's even more difficult.
You're numbers are basically less than 10% lower than what you expected, the temperature alone could easily account for that much.
JacktheBagger and RGKen like this.
tdkkart is offline
post #8 of 38 (permalink) Old 08-10-2015, 03:56 PM
pat123's Avatar
You're numbers are basically less than 10% than what your expected, the temperature alone could easily
All very true BUT the AFR's are way off. Wait a second the all mighty tmax will fix that,it's a autotuner.... LOL
pat123 is offline
post #9 of 38 (permalink) Old 08-10-2015, 04:57 PM
JacktheBagger's Avatar
Getting 1 HP per CI is pretty good with a Harley ..
Never understood the fanaticism over Dyno sheets .
I don't care if it delivers 110 HP/TQ at 5000 rpm .. My motor don't live at 5000 rpm ..
To each his own , I gave up chasing HP/TQ numbers long before every dealer had a Dyno ..
JtB
2011 Ultra
JacktheBagger is offline
post #10 of 38 (permalink) Old 08-10-2015, 05:13 PM
JtB
Feels good passing a truck, but I'm with you JTB.
Harleys are SLOW period! You have to pour THOUSANDS into a Harley to make it even fun(if fun is defined by speed).
2013 RGU upgrade - happy, happy, happy Red Dawg Dyno Results 9 03-17-2014 07:01 PM
Happy! Happy! Happy! With J&M!!! HeatWave J&M 1 12-01-2013 11:25 AM
Happy happy happy Road08Glide J&M 6 03-30-2013 11:00 PM
happy for but not happy with rossmann *General Road Glide Discussions/Pictures 21 06-30-2011 06:59 AM
Happy Happy Ducflames904 *General Road Glide Discussions/Pictures 3 01-01-2011 10:38 AM
