09 106" with head work andrews 57 and dragula exhaust - Road Glide Forums
post #1 of 11 (permalink) Old 09-13-2012, 11:42 AM Thread Starter
Guys here is a dyno sheet I got last night.
Specs are......
Ported Head work.
106 inch motor
Andrew 57 cams
TTS master tune
Dragos Dragula 2:1 2.55 baffle
I did not build motor just exhaust is ours... I want to show people the Andrew 57 here and its power band..
Nice work guys just like we talked about on the phone.....
File Type: jpg 106 INCH HEADS AND DRAGULA ANDRES 57 CAM.jpg (88.4 KB, 404 views)
DragoBikeWorks is offline
post #2 of 11 (permalink) Old 09-13-2012, 11:46 AM
connector's Avatar
Some impressive numbers
09 FLTR 103 Stage III
connector is offline
post #3 of 11 (permalink) Old 09-13-2012, 12:52 PM
spokanebagfan's Avatar
Nice overall #'s, i was hoping the 57 would come on a little earlier. The power is out there a little ways in the rpm, range. Frank any idea of compression they ran with that one, mostly curious if the 57 really need higher compression to perform.
spokanebagfan is offline
post #4 of 11 (permalink) Old 09-13-2012, 02:31 PM Thread Starter
If you look at the power it comes on at 2200 rpm over 100 ft tq. Thats not bad.
I my self have not had the chance to use them.
There static compression. with this cam 10.1/10.25 max....
here is there website
http://www.andrewsproducts.com/motorcycle-parts/catalog
Andrews 57 comes 2200/5500
post #5 of 11 (permalink) Old 09-13-2012, 03:49 PM
Frank with the cost of this cam around 280, would this be something you would steer guys towards compared to the 55tq at like $380, i thought i read somewhere that this came was comprable to that one?
post #6 of 11 (permalink) Old 09-13-2012, 04:09 PM Thread Starter
The tman cam is 348.00
Yes the Andrews 57 is a nice low to mid range cam.
I dont have any side by side compression yet.
I hope to soon.B
But I would say yes.
post #7 of 11 (permalink) Old 09-13-2012, 05:38 PM
mocotom's Avatar
Most riders use the 2200 to 4500 rpm range about 90 percent of the time. That is very good numbers for mild cam 106 motor.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #8 of 11 (permalink) Old 09-13-2012, 06:35 PM
the other part of the recipe is that it has an excellent set of heads. Sweet combo and sweet numbers.
jeff is offline
post #9 of 11 (permalink) Old 09-13-2012, 07:22 PM
Admin
BillyBob's Avatar
Numbers look nice. Looking at a 107 too
BillyBob is offline
post #10 of 11 (permalink) Old 09-13-2012, 10:18 PM
Frank,
That looks pretty nice. Assume it's a 6th gear pull??
Jeff
akjeff is offline
Andrews 26 to Andrews 57 Bill-99RG Engine Related 2 02-29-2016 06:28 AM
PV/ Andrews 57/ H Pipe/ 103 Wmoor004 Map Section 3 02-13-2015 06:39 PM
09+ Tour Pak Mount (53411-09) and Side Covers (L-47526-09, R-47522-09) bikerglasses Parts for Sale 3 12-06-2013 10:33 AM
Head work and Dragula miker717 Dyno Results 14 04-06-2013 10:59 PM
