2009 FLTR w/120R Tman 625G - Road Glide Forums
 2Likes
post #1 of 13 (permalink) Old 08-19-2015, 12:02 AM Thread Starter
4th gear pull.
120R crate motor, with the following mods.
Heads by Don/HDSP Comp at around 10.2:1
HPI 55/58 TB w/5.3 injectors
S&S roller rockers
Smith Bros adj rods
TMan 625 gear drives
Jackpot XXX 2/1/2 headers
Nightsticks with cores replaced with Supertrapp perforated and wrapped baffles w/14 discs and closed end cap
Tuned mostly on the street with PV w/wide bands & Auto Tune. Paid for an hour of dyno time to hit the cells I didn't have the balls to hit on the street, and made one last correction after that. Gained 5/5 over my street tune. I did not touch the timing. I'm sure my DIY tune left power on the table, but it runs great, and I'm happy with it.
A big thanks to all who helped, with either services, and/or advice! :beer:
Jeff
RGKen likes this.
akjeff is offline
post #2 of 13 (permalink) Old 08-19-2015, 08:58 AM
apgharleymech's Avatar
Originally Posted by akjeff View Post
4th gear pull.
S&S roller rockers
Smith Bros adj rods
Jeff
Why did you choose to go with the PV tuner?
Shiny and New '16 FLTRXS
Harley Davidson Arizona Proving Grounds
Mech Level 1
apgharleymech is offline
post #3 of 13 (permalink) Old 08-19-2015, 06:48 PM
Nice curves!! I love the T-Man 625s...
RGKen likes this.
HeatWave is offline
post #4 of 13 (permalink) Old 08-19-2015, 08:35 PM
jack6hd's Avatar
+1 on the T-Man 625's
2015 FXDL 2nd best HD on road
jack6hd is offline
post #5 of 13 (permalink) Old 08-19-2015, 11:41 PM Thread Starter
"Why did you choose to go with the PV tuner?"
It's fairly simple for a home hobbyist, and it works! For me, anyway. Great support from Fuel Moto, if you get stuck.
Jeff
akjeff is offline
post #6 of 13 (permalink) Old 08-19-2015, 11:42 PM Thread Starter
"Originally Posted by HeatWave View Post
+1 on the T-Man 625's"
Yep, very bagger friendly cams.
Jeff
akjeff is offline
post #7 of 13 (permalink) Old 10-25-2015, 02:58 PM
Can you post a few photos of the Supertrapps ?
Another question ,, Is this bike loud?
George W is offline
post #8 of 13 (permalink) Old 10-30-2015, 06:00 AM
If the timing is untouched, then there is more in that.
Looks very similar curve in comparison to a Wood TW-400, when used in similar combos.
Should be fun.
Scott
Hillsidecycle.com is offline
post #9 of 13 (permalink) Old 10-30-2015, 08:17 AM
124shark's Avatar
Looking at how smooth the lines are and shape of curve.. You are very close to peak.. I would advise that you leave your tune just as it is.. As it is not showing any signs in that pull of needing more timing added. Looks like you spent the time data logging and getting it dialed in.
A pull in 6th gear would add 5-7 on tq and 2-4 on hp from what I have seen.
Looks good
2012 FLTRX 124 S&S
124shark is offline
post #10 of 13 (permalink) Old 11-02-2015, 11:52 PM Thread Starter
Should be fun.
Scott
I'm sure you're right on Scott. With the 5/5 I gained using the dyno to polish up the fueling, I'm sure a timing tweak would sharpen the tune even more. My exhaust choice is likely a handicap as well. I wanted it quiet. If I were to add some discs, and an open end cap, I suspect my top end would improve. I may do that just for the track(along with a re tuned map for it).I made it to the last test & tune night before our track closed for the season, and made my first runs down a strip. Best run was 13.2/104mph. Had a bitch of a time keeping the stock Dunlops hooked up. Very first run was a 1st & 2nd gear rolling burnout! Got a little better/faster each run. Gotta do some more of that next season! Would like to get to the mid 12's.
Jeff
akjeff is offline
2009 FLTR CA Bike, Located in AZ dirtbag Classifieds Archive (3 months old+) 5 04-01-2012 03:50 PM
2009 fltr seat Road Glide oldtimer63 Sold 6 03-24-2012 02:19 PM
Part/Casting numbers for 2009 FLTR stock mufflers? jdbaker Intake and Exhaust 5 02-11-2012 03:22 PM
Be wary of trying to install on 2009 FLTR RMinucci Windshields 12 06-28-2010 07:30 AM
Installing Heritage bars on a 2009 FLTR twowheel99 Controls & Handlebars 3 04-01-2010 01:13 PM
