What can I expect? - Road Glide Forums
  • 1 Post By ironmark
post #1 of 7 (permalink) Old 08-19-2015, 04:21 PM Thread Starter
Brianu1's Avatar
What can I expect?
I am having the TW-777 cams installed next week. I have the V&H power duals, CFR pipes, SE Ventilator A/C, and PC5.
I am thinking based on other sheets and bikes of around 92-95hp and 110-115tq?
That should be an increase of about 10-15 in both categories right?
FLTRX, Black Edge Cut Blade wheels & rotors, RSD Seat, TW-777, V&H Power Duals w/ CFR's, Daymakers, SE A/C, PV tuner, Soundz Customz LV-4 audio, Klockwerks Flare 12" smoke, CD LED's, Progressive shocks, & lots of others...
Brianu1 is offline
post #2 of 7 (permalink) Old 08-19-2015, 04:34 PM
pat123's Avatar
Those 777's would really shine @ 10.4:1 compression. With stock compression it's going to be soft on the bottom.
It really depends what your wanting to do. If your chasing numbers. Bump that compression and loose those CFR pipes and go with a 2:1 or if You just want a little more powerful ride. Install,tune and enjoy.
pat123 is offline
post #3 of 7 (permalink) Old 08-19-2015, 04:50 PM Thread Starter
Brianu1's Avatar
I am not looking to get to any specific number or numbers. Don't really care, just more curious I guess.
Mainly just to have some more power for riding and a bigger grin on my face whilst I do so!
Brianu1 is offline
post #4 of 7 (permalink) Old 08-20-2015, 11:10 PM
Taccone's Avatar
With not having the bumped up compression that the 777's thrive on and having CFR mufflers I'd say expect hp to in the low-mid 90's range and torque should be in the low-mid 100's. But once you switch to a 2 into 1 exhaust and bump up your compression ratio you can expect to see those numbers soar up quickly!
Taccone is offline
post #5 of 7 (permalink) Old 08-20-2015, 11:19 PM
The Tw 777 cams need more compression than the stock HD engine provides so you will be totally disappointed in this upgrade unless you do more engine mods.
The TW 222 or 555 would be a much better cam to use with a stock engine. The TW 777 cams need the engine to run at a much higher rpm (3000 +) to be a efficient cam for your bike.
nsbohall likes this.
post #6 of 7 (permalink) Old 08-20-2015, 11:40 PM
nsbohall's Avatar
Like Ironmark said, you might be disappointed if installing these in a stock motor. Fuel Moto website has some dyno charts of the 777 in a stock motor compared to one with their 107 kit with their level B heads. The combo of those big cams and the CFR's will probably be disappointing. Bigger cams usually require more compression to get the full potential out of them, not to mention that they may require stronger valve springs to handle the lift. JMO, good luck.
2013 FLTRU, S&S Power Tune Duals, Supertrapp Stouts, Andrews 48's, AN Big Sucker, Direct Link, Fuel Moto LED's, Custom Dynamics, 14.5 Madstad, 14" Carlini's, Legends AXEO and Revo A's.
nsbohall is offline
post #7 of 7 (permalink) Old 12-20-2015, 02:08 PM
Yep u will not be happy I swapped a set of cycle rama cams out on now I have a dip down low with the 777. I called they like more compression
milkman48 is offline
What I can expect? Poppi07 Intake and Exhaust 12 10-24-2014 08:40 AM
What can you expect from a new map? georgepink Map Section 1 12-12-2013 10:08 AM
Any Ideas on what Torque/HP numbers I can expect? AZroadrunner Engine Related 12 04-09-2011 12:19 PM
Painted inner fairing...what can I expect to pay? Q-Dog *General Road Glide Discussions/Pictures 15 03-27-2011 01:50 PM
