125/131 - Road Glide Forums
 5Likes
post #1 of 15 (permalink) Old 11-16-2015, 09:09 PM Thread Starter
Sleepybagger's Avatar
125/131
I wanted a reliable 130/130. Might install a 2 into 1 and retune.
Out of the pocket I am through that dip so fast I never knew it was there until I saw it on paper.
2015 113" 125/131
Sleepybagger is offline
post #2 of 15 (permalink) Old 11-16-2015, 09:45 PM
ITOLDU's Avatar
Nice work Sleepyabagger, that bad boy is definitely not sleeping anymore!
ITOLDU is offline
post #3 of 15 (permalink) Old 11-16-2015, 11:37 PM
I have the same dip. If you didn't see it on paper, you would never know it was there. I have a Drago 2 into 1. A 2 into 1 will give you a little more. My TQ is a little higher then my HP
00se1550 is offline
post #4 of 15 (permalink) Old 11-16-2015, 11:41 PM
hd4cruzin's Avatar
Bob does some nice work. Should be a fun ride!
2012 FLTRX BBP
hd4cruzin is offline
post #5 of 15 (permalink) Old 11-17-2015, 10:22 AM
glide69's Avatar
Nice numbers, that will be a FUN ride!
2018 FLTRXS Wicked Red
glide69 is offline
post #6 of 15 (permalink) Old 11-17-2015, 10:38 AM
NorCal's Avatar
looks great, Ron at R C Cycle does good work and Bob is an ace on the dyno
NorCal is offline
post #7 of 15 (permalink) Old 11-19-2015, 08:12 AM
MyGlide's Avatar
Looks good! Maybe you should change your name from Sleepybagger to Sleeperbagger.
2018 KTM Super Duke R
MyGlide is offline
post #8 of 15 (permalink) Old 11-19-2015, 08:17 AM
Sleepy bagger: can you fill us in on your build? The dyno sheet says 103"?
dozer23 is offline
post #9 of 15 (permalink) Old 11-26-2015, 12:55 PM Thread Starter
Went with the HD 113 barrels just for that
2015 113" 125/131
post #10 of 15 (permalink) Old 11-26-2015, 01:08 PM Thread Starter
HD 113 barrels, 10.2:1, S&S 4-3/8 crank, timken, S&S 635HO, reworked HD CNC heads, port matched 58TB, 5.3, Aim, TTS, S&S Power Dual w/Rinehart 4".
1st and 2nd 2800-5500 is hard to manage. I am getting used to shifting at 5000 and pushing the RPM in higher gears. I cannot imagine a Glide making 140+ in that RPM range........insane!
RazorHog and apgharleymech like this.
2015 113" 125/131
2007 FLTR R&R 131 Baker DD7 > 100K chriscalabro Road Glide Builds-Document your builds HERE --NEW 5 09-14-2016 05:56 PM
Installing SE Hurricane heads on 131 inch DragoBikeWorks Engine Related 30 11-10-2012 07:56 PM
Streamliner Passenger Footpegs $125 jimmyray11349 Classifieds Archive (3 months old+) 0 06-01-2011 08:45 PM
131 ci R&R digga25 Engine Related 8 05-24-2011 07:38 AM
WTB ARC AUDIO KS 125.4 MINI 500W amp - used or inexpensive Timinfla2 Classifieds Archive (3 months old+) 0 04-24-2011 10:54 AM
