2015 FLHX, FM 107, Level C heads, TW8-6 cams - Road Glide Forums
 10Likes
post #1 of 22 (permalink) Old 01-25-2016, 04:40 PM Thread Starter
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Here is a chart from on of our dealers, Pure Powersports in Crystal Lake, IL. This is one of our hi output 107 combination's in a 2015 FLHX:
Fuel Moto 107 kit 10.75:1 comp
FM Level C CNC heads
Wood TW8-6 cams
He was running V&H PowerDuals w/V&H slip ons, SE intake, stock TB & injectors, stock crankshaft, dyno tuned with Dynojet Power Vision.
Dyno chart comparing 2015 FLHX, FM 107 Hi Output build vs stock 103 engine with exhaust, SE intake, base tune
BrownSanta likes this.
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #2 of 22 (permalink) Old 01-26-2016, 06:50 PM
jack6hd's Avatar
Very nice numbers with a stock TB and injectors. Well done.
2015 FXDL 2nd best HD on road
jack6hd is offline
post #3 of 22 (permalink) Old 01-27-2016, 05:53 AM
Looks good.
On Wood's site, there is a 107"/TW-8 cam, that is making 141 hp.
Scott
Smarty likes this.
Hillsidecycle.com is offline
post #4 of 22 (permalink) Old 01-27-2016, 07:01 AM
Nordic Berserker's Avatar
Very nice
Nordic Berserker is offline
post #5 of 22 (permalink) Old 01-27-2016, 10:37 AM
Nice....are they new jugs in those kits or bored out stock 103 jugs? Seems like no one is having any issues with the stock ones bored out to 107 as far as longevity. Thanks
JJSHARKNOSE is offline
post #6 of 22 (permalink) Old 02-02-2016, 02:40 PM Thread Starter
fuelmoto's Avatar
This build was done with bored factory cylinders. We do also offer our extreme duty IC cylinders as well. Both work excellent
JJSHARKNOSE likes this.
Email
fuelmoto is offline
post #7 of 22 (permalink) Old 02-16-2016, 06:04 AM
Originally Posted by Hillsidecycle.com View Post
Looks good.
Scott
"B" engine/Axtell 4 1/8" cylinders/Our Stage IV Heads/HPI 55/58 Max Flo/D&D Fatcat BB baffle, Hoban Crank balanced to our specs/Wood TW-8G/200 psi ccp.........old news.
Scott
post #8 of 22 (permalink) Old 02-17-2016, 01:05 PM Thread Starter
fuelmoto's Avatar
Scott
What does a different model 10 year older bike with a different bore/stroke and completely different components have to do with the build this dealer built in this thread? not to mention it was tuned on a different dyno, in a different state, and the chart has a different correction factor. Am I missing something?
Email
fuelmoto is offline
post #9 of 22 (permalink) Old 02-20-2016, 06:15 PM
Wow! Scott:
You like too push everybody's button's
SMOKENJOE and RGKen like this.
dozer23 is offline
post #10 of 22 (permalink) Old 02-21-2016, 11:04 AM
Wood TW8-6 cams
Back to the subject. Jamie, are the 10.75 compression ratio and the C heads really street usable or is this more of a straight drag setup? Any heat issues?
303RG is offline
2018 FLHX 107 Redshift 468 cam Bassani 2/1 fuelmoto Dyno Results 1 07-12-2018 11:59 AM
2017, 120" M8, FM Level B heads, WM8-999 cam, Jackpot 2/1 fuelmoto Dyno Results 13 01-05-2018 07:34 AM
FM Engine parts Sale, Big Bore kits, Level B heads, Cam packaged & more fuelmoto Fuel Moto 0 01-03-2017 10:39 AM
2012 103" Wood TW-777 cams FM Level B Heads fuelmoto Dyno Results 6 12-16-2013 01:07 PM
PV map for 106/107 kit, 57H cams and heads mffi497 Map Section 1 11-25-2013 09:00 AM
