Just tuned yesterday.... - Road Glide Forums
 5Likes
post #1 of 26 (permalink) Old 02-12-2016, 04:39 AM Thread Starter
apgharleymech's Avatar
So after finally finding an exhaust that I REALLY like for a price I couldnt pass up.... My 16 FLTRXS is running MGS True Duals, a Harley Stage 1 breather kit with no cover, and I decided on a TTS Mastertune. Kelly at Performance Specialists in Kingman, AZ Tune my bike in only a few runs (he said) yesterday afternoon. I'm thinking the lack of runs and time spent is partly reasoning for my Torque curve to not be quite as smooth as my HP curve. Although I know dyno sheets can be fooled... my ass was firmly planted when I hit the throttle on the first straightaway I got to...and good thing!! My bike pulls! Not quite in the RPM rang I'm really looking for...but cams will come this summer
All in all... 80.08 HP and 96.89 TQ... for my stock 103HO motor breathing a little better now..I'm happy with the numbers, but more happy with the feel!! Guess the next question is how my mileage is going to be affected...
Shiny and New '16 FLTRXS
Harley Davidson Arizona Proving Grounds
Mech Level 1
apgharleymech is offline
post #2 of 26 (permalink) Old 02-12-2016, 04:57 AM
sj01fltri's Avatar
Congrats on the good tune i will be getting a tune this spring using a TTS Master tune,hoping to get rid of a flat spot i have with my cobra tuner.
sj01fltri is offline
post #3 of 26 (permalink) Old 02-12-2016, 08:33 AM
Swomack's Avatar
Congrats
My Gallery / Click Below Link
Swomack is offline
post #4 of 26 (permalink) Old 02-14-2016, 08:39 AM
Pretty nice numbers. Wait until you get the cams in there. I was torn between the Screamin eagle 204 cams or the Andrews 57h cams. Ended up ordering the Andrews last night along with some .030 head gaskets..
Badass355ciz28 is offline
post #5 of 26 (permalink) Old 02-14-2016, 09:46 AM
Smarty's Avatar
Just food for thought. When you get what ever cams in the future, get a good dyno guy to smooth out your torque curve. With a little time and massaging, he should be able to give you a real smooth torque line with out the wiggles all along the torque curve. You will be much more happy with the results.
sloride likes this.
Smarty is offline
post #6 of 26 (permalink) Old 02-14-2016, 06:57 PM
Desertwndrr's Avatar
The wiggles are because he had the smoothing set to zero.
A full tune should take 20-30 runs. I'm betting that he stuck in a Stage I tune and then just worked the full throttle run. I'm sure that it runs great full throttle but how does it run throughout the rest of the ranges?
sloride and Smarty like this.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #7 of 26 (permalink) Old 02-15-2016, 11:59 AM
Smarty's Avatar
My buddy that does dyno tunes and I went to the V-Twin Expo in Cincinnati a few weeks back. He uses Direct link. Direct Link has a separate device that once you do the initial pulls and get the numbers in all the boxes, it gives you what should be in the boxes that need to be corrected. He then transfers the repaired boxes and then starts the real tuning pulls with these numbers installed. It's amazing how it cuts down on the fine tuning time. What normally would take 3-4 hours can now be done in 1 1/2 hours. The device uses the oxygen sensors to predetermine off the first good pull to set some values. Also, it doesn't use the harley sensors. IF there is not bungs 3"s or so away from the head, he has these bungs that you drill a hole under the heat shields and they slip in and use a bolt to collapse the back side for a completely sealed fit. He then hooks his Direct link sensors there for the perfect readings instead of in the end of the pipe. Once finished, there is a small screw or plug the goes in the device and the heat shield goes back on. He does some nut on dyno work. Got to love the new technology, well new to me anyway.
2016 RGS Black Quartz
Smarty is offline
post #8 of 26 (permalink) Old 02-16-2016, 02:49 AM Thread Starter
You'll have to let me know what you think of the Andrews...I'm debating between that one and mainly the Tman 555 Torqster...They look similar on print outs, but I know there are small differences. What was your reasoning behind the head gasket swap?
Mech Level 1
post #9 of 26 (permalink) Old 02-16-2016, 02:52 AM Thread Starter
I think it feels pretty smooth all around. And yes, WOT is pretty decent as well. This is the first time I've had a bike tuned, so I don't have a whole lot to go off of... The AFR table seems a little off to me though. And the last two tanks I've put through it seems like my mileage isn't quite what I was expecting. I keep reading that guys are getting between 38 to 42s, but I can't seem to break 38... I run highway mostly, 80 mph cruse control. Maybe something's off with the AFRs?
Mech Level 1
post #10 of 26 (permalink) Old 02-16-2016, 02:53 AM Thread Starter
Any recommendations? Yes, I see you live in Texas, but I'm up for an excuse for a long couple days ride...
Mech Level 1
Did something just plain crazy yesterday... Torquey *General Road Glide Discussions/Pictures 32 08-27-2012 06:37 PM
S&S Tuned Induction Dual Air Cleaner FLboi85 Intake and Exhaust 2 02-04-2012 08:16 PM
FS s&s twin 50mm tuned induction bigpete1 Classifieds Archive (3 months old+) 0 12-01-2011 06:26 PM
Tuned up Wharf Rat Road Glide Specific Discussions 6 10-30-2011 01:11 AM
2011 RGU Dyno Tuned harleson Road Glide Specific Discussions 12 02-12-2011 02:49 PM
