What questions to ask of a Dyno Tuner? - Road Glide Forums
post #1 of 4 (permalink) Old 12-02-2012, 09:45 AM Thread Starter
Hullhorr's Avatar
I am very close to having my dyno tune done after my 107 and cam build. I have never dyno tuned before and wonder what questions to ask. I spoke with my local dealer and they want $400. A Indy about 30-miles away advertises $200. I've read that $300 is about normal cost wise.
I have a power commander V. Should I only use someone that uses the dynojet Dynometer for a proper tune or would any dyno machine be able to do the job? There is a Indy in Winchester, VA (Skips) that is an hour and a half away that has good reviews from people on here, but doesn't use the dynojet.
2009 FLTR MOP
Hullhorr is offline
post #2 of 4 (permalink) Old 12-02-2012, 08:39 PM
easyrider9809's Avatar
I would find a tuner that is experienced and reputable. Make sure the tuner has familiarity with your type of build since your putting in an aftermarket cam. Also make sure the tuner is comfortable using the power commander software.
My personnal experience having the local hd dealership dyno tune with a aftermarket cam install....... Was one step away from being disastrous. I'm fortunate that I live less than two hours away from Jamie at Fuel Moto.
easyrider9809 is offline
post #3 of 4 (permalink) Old 12-13-2012, 10:34 AM
Easy rider is right, find someone that knows the PC 5 and will go thru all the tables for your AFR's. make shure they remove youe tip when they put in the sniffers as not to damage it. and a good tunner that does not just make hard pulls, then hand you a sheet and say ok your all done. Good luck and let us see the out come.
chuck the wrench is offline
post #4 of 4 (permalink) Old 12-13-2012, 03:02 PM
StephenRG's Avatar
Something else ot keep in mind is timing. You can adjust your A/F ratio as much as you want but if you don't touch the timing you are not maximizing your build.
Also, as was said before, make sure they know how to do loaded runs, not just WOT.
Stephen
'10 RG "Black Betty"
HQ 103"
HQ 575 cam
SEPRT
16" TRSSC Cee Bailey Windshield
Sancho's Wings
Mustang Seat
J & M Speakers
Drago's True Duals
Apparently not as black as I thought...
StephenRG is offline
T max tuner questions. Dyno results milkman48 ECM/Fuel Management systems 1 09-12-2014 11:31 AM
Just got to ask HONDA? Frodoe General Off-Topic Discussions 12 05-18-2012 05:08 PM
I know it's blasphemy, but I have to ask twalte Road Glide Specific Discussions 22 08-22-2011 12:35 AM
My Wife ask why Harley Road Glide? Bruno3290 New Members Welcome Area 36 02-27-2011 10:53 AM
Questions to ask Dealer re: buying bike joke *General Road Glide Discussions/Pictures 8 12-09-2009 02:07 PM
