117" Harley kit dyno results - Road Glide Forums
 2Likes
  • 1 Post By Smarty
  • 1 Post By MTrider
post #1 of 10 (permalink) Old 05-12-2016, 05:11 PM Thread Starter
MTrider's Avatar
2015 Road Glide Ultra CVO FLTRUSE
For anyone that may be considering the bolt-on 117 kit--very pleased with my results!
  • 117" Race kit 92500053 with 259E cams
  • Heads milled .010" (installer found a flaw in gasket surface of head)
  • .030" Cometic head gasket 68-10086-30
  • D&D Boss Boarzilla 2 into 1 exhaust
  • SE Race tuner
124.58HP/125.15TQ
Installed & tuned by Yellowstone Harley, Belgrade MT
MTrider is offline
post #2 of 10 (permalink) Old 05-12-2016, 05:41 PM
SteadyEddie's Avatar
Nicely done
SteadyEddie is offline
post #3 of 10 (permalink) Old 05-12-2016, 06:08 PM
twowheeladdict's Avatar
Quite an increase in output.
How does it affect everyday riding? MPG? RPMs at 70 mph?
Is the rest of the drivetrain up to the task?
twowheeladdict is offline
post #4 of 10 (permalink) Old 05-12-2016, 06:16 PM
09Sharknose's Avatar
Forgive me for failing to do my due diligence and research, but what were the original numbers on your scoot?
09Sharknose is offline
post #5 of 10 (permalink) Old 05-12-2016, 06:16 PM
RGKen's Avatar
RPMs to MPH will be the same unless he changed the gear ratio somewhere in the drive train. Adding HP/TQ alone will not affect it.
MTrider,
Great numbers! Looks fun so keep us posted on how it does for everyday riding!
2018 FLTRXS
RGKen is offline
post #6 of 10 (permalink) Old 05-12-2016, 07:16 PM
madmat's Avatar
Great looking numbers, bet it pulls quite well
18 RGS Bonneville Salt Pearl
madmat is online now
post #7 of 10 (permalink) Old 05-12-2016, 07:32 PM
Smarty's Avatar
Nice job. Just take care of the bottom end. No high revs and dumping the clutch. Be a big uh oh. If it's tuned right, should get 40-42 mpg easy.
RGKen likes this.
2016 RGS Black Quartz
Smarty is offline
post #8 of 10 (permalink) Old 05-16-2016, 10:04 AM Thread Starter
MTrider's Avatar
*Everyday riding: Much better! Some loss on the very low end with these cams, but the increased displacement helps make up for that. These cams come on very strong by about 2,500 rpm, with plenty of pull through the entire range (even with 2 people and extra gear), where the original 255 cams ran out of steam after about 4,000 rpm.
*MPG: I haven't checked on paper to verify, but based on the rides I've done, I'd say it dropped 1-2mpg at the very most--still have plenty of range between fill ups.
*RPM's are still the same--no change in gearing or tire size.
*Rest of the drivetrain: Everything should be up to task with a build this mild. The clutch is working well, but likely the 1st weak point. Info from Harley varies--depending on where you read, they say the original CVO A&S clutch is good for 115-135ftlbs, but I will likely be putting an AIM kit in it soon to be on the safe side.
As SMARTY pointed out, the crank can be an issue if abused, but that shouldn't be a problem with my riding style.
twowheeladdict likes this.
MTrider is offline
post #9 of 10 (permalink) Old 05-16-2016, 10:15 AM Thread Starter
MTrider's Avatar
I didn't do a baseline dyno on the bike when new, but based on what I've read, a stock CVO would be 80-83hp.
After the 1,000 mile break-in, the only change we did was replace the factory pipe with a Python Rayzer(short 2into1) and ended up with 90.24hp/113.31tq after tuning, so I gained an honest 35hp with the 117 kit.
MTrider is offline
post #10 of 10 (permalink) Old 05-16-2016, 10:24 AM
Bruce00's Avatar
Congrats, I bet it made a nice ride more fun to ride.
Many safe miles
2015 RoadGlide Special
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
2018 CVO 117" dyno testing Fuel Moto fuelmoto Dyno Results 4 11-14-2017 02:45 PM
Dyno results 103" TW-777 cams Brianu1 Dyno Results 20 03-14-2016 01:16 PM
2015 RGS 113" Dyno Results Bigracks Dyno Results 5 12-03-2015 09:50 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 09:31 AM
