2004 103 Rebuild motor. 114HP 124TQ. - Road Glide Forums
post #1 of 8 (permalink) Old 12-29-2012, 06:25 PM Thread Starter
Here is a dyno sheets on a 103 rebuild we did
Re did the heads Stage 2.5 DBW heads
New Tman 660SM cam ( in a 110 plus this cam rocks
New pistons Wisceo 10.5.1 compression
Dragula pipe
Thundermax Autotune.
Forgot to say HPI 51 mm throttle body... Old stock one can only bore out to 46mm
Dragos Custom 4.8 g/s injectors
3.875 bore
4.3/8 stroke === 103.191 inch
114 HP Sae 5 124TQ
117 HP STD 5 126TQ
4th Gear pulls 2000 grand rpm
5th gear at 2500 grand rpm
We only put 70 miles on it on dyno and did 3 pulls with tmax autotune Custom map By Dragos Bike Works
Need more break in time after 1000 miles I will re tune it and play with timing. Should do even better.
DragoBikeWorks is offline
post #2 of 8 (permalink) Old 12-29-2012, 06:46 PM
connector's Avatar
Numbers and flat top look great , 103 that rocks . Thank chr:st i was vieing on my lap top though ,would of hated to have to turn my monitor sideways to read that graph
09 FLTR 103 Stage III
connector is offline
post #3 of 8 (permalink) Old 12-29-2012, 11:54 PM
Were you using the stock throttle body and injectors or did you upgrade to a bigger TB and injectors. That is good #'s on that build.
post #4 of 8 (permalink) Old 12-30-2012, 12:04 AM
Q-Hog's Avatar
I want those numbers, Frank..
Q-Hog is offline
post #5 of 8 (permalink) Old 12-30-2012, 12:24 AM
INDEPENDENT 1
Guest
Posts: n/a
wow.................
post #6 of 8 (permalink) Old 12-30-2012, 12:20 PM Thread Starter
I added it in on my post....Thanks
post #7 of 8 (permalink) Old 12-30-2012, 12:26 PM
How much of the performance gain did the TB and injectors give the bike over the stock TB and injectors? Just wondering because I am still thinking about a bigger TB and injectors.
post #8 of 8 (permalink) Old 01-13-2013, 06:38 PM Thread Starter
The stock injectors were at max 99% duty.
The bigger throttle helps out with 3/5 more HPs and tq cross the curve.
More air in more out more power..
Would You Buy a Dealer Motor Rebuild? SteadyEddie General Off-Topic Discussions 31 07-09-2016 09:04 AM
103 in a 2004 Tee Engine Related 15 06-12-2016 09:15 AM
88K miles and need motor rebuild? RoadGlideRider Engine Related 11 06-10-2015 11:32 PM
'10 103" with HQ motor StephenRG Dyno Results 5 01-06-2013 10:41 PM
103" motor with sweet upgrades!!! Comes with crate & stand i_timmers Classifieds Archive (3 months old+) 3 08-14-2012 10:15 PM
