Can someone explain - Road Glide Forums
 5Likes
  • 1 Post By Big_gary
  • 2 Post By Big_gary
  • 1 Post By SMOKENJOE
  • 1 Post By MyGlide
post #1 of 7 (permalink) Old 08-01-2016, 07:22 AM Thread Starter
bigqdiddy's Avatar
Can someone explain
Not to sure about how to read a dyno sheet this is a stock 2013 FLTRX with vance and hines x pipe rinehart 4 inch mufflers a and screamin eagle heavy breather used the screaming eagle race tuner these were the dyno result ... any goo please let me know
Excuses are monuments of nothingness that build bridges to nowhere those that use these tools of incompetence are masters of nothingness
bigqdiddy is offline
post #2 of 7 (permalink) Old 08-01-2016, 07:49 AM
Top read out are your total output numbers, before/after tune. Below is the graph of the power curve , before/after tune.
bigqdiddy likes this.
post #3 of 7 (permalink) Old 08-01-2016, 08:50 AM Thread Starter
bigqdiddy's Avatar
Thanks big gary about cost almost 2grand for 4.5 horsepower and 5 ft/lbs of torque ...whatever i absolutely love this bike so it really dosent matter now does it
post #4 of 7 (permalink) Old 08-01-2016, 09:34 AM
That's the cheap HP. Form this point on it really gets expensive.
madmat and bigqdiddy like this.
post #5 of 7 (permalink) Old 08-05-2016, 10:59 AM
SMOKENJOE's Avatar
I DID MY OWN WORK HERE IS THE COST FOR ABOUT 44 ADDED HP AND 34 MORE FOOT POUNDS OF TQ PLUS EXTRAS
DAYTONA HIGH VOLUME HIGH PRESSURE OIL PUMP HARLEY TWIN CAM 2007-2013 $124.95
S&S 106 Inch Big Bore Kits for Twin Cam (07-UP) $664.95
S&S Cycle Premium High-Performance Tappet with HL2T Kit $230.82
S&S Cycle Rocker Box Gasket Kit for Harley 99-13 OE Twin Cam Rocker Boxes 46.00
OIL PUMP O RINMGS 7.00
SCREAMIN' EAGLE PR O HIGH FLO W 58MM EFI INDUCTION MODULE 355.00
58MM 5.3 INJECTORS 117.00
Port Matched 58mm Throttle Body To 79CC heads
S&S 585 Cams for Harley Davidson 2007-13 Twin Cam $274.01
BDL New Design Compensator Sprocket for Big Twins - 34T 159.00
Barnett Clutch 100.00
S&S Cycle Super Stock 79cc Cylinder Head Kit - .640in. Lift Springs - Winkle Black 106-3233 $959.42
TOTAL 3065.15
Memphisglide likes this.
SMOKENJOE is offline
post #6 of 7 (permalink) Old 08-05-2016, 12:19 PM
Memphisglide's Avatar
Im thinking the numbers don't look right if "stock" before...ask shop who did the tune what the baseline (lower numbers) represent.
2016 Road Glide Special - Black Quartz
Memphisglide is offline
post #7 of 7 (permalink) Old 08-06-2016, 07:27 AM
MyGlide's Avatar
I'm thinking those lower numbers are already in the ballpark for a 2013 with a stage 1. This doesn't look like from stock to stage 1 but rather a better tune the second time.
2018 FLTRU (mistake)
2018 KTM Super Duke R
MyGlide is offline
Can Someone Explain Ohms To Me? The Volusianator Audio 15 06-20-2018 11:25 AM
2ohm and 4ohm? can someone explain cookie114 Audio 30 02-21-2016 04:02 PM
Can somebody explain (dumb down) RMS power to me? steel breeze Audio 4 03-22-2015 10:58 PM
can anyone explain CVO TBW 13HDGLIDE Controls & Handlebars 12 01-26-2013 08:27 AM
Can some one please explain this HDMARK *General Road Glide Discussions/Pictures 1 02-09-2012 06:44 PM
