Docs-Dragula & T Man - Road Glide Forums
post #1 of 8 (permalink) Old 01-19-2013, 03:17 PM Thread Starter
tj316's Avatar
I got my bike back from Docs today , I had Cycle Rama CR575 cams , A/C , Bassani B-4 2 into 1 pipe , TTS Tuner , Baisley Super Stock Heads in the first dyno sheet , the second sheet I changed the cams to T Man 600 cams and my pipe to the Dragula with the 2.55 baffle , I gained 3 hp & 3 trq , if you look at the 2 charts I lost a little at at the 2500-3200 rpm range but riding it I don't fill it , but I gained on the top end , on the 1st sheet I drop below 110 trq at 4300 rpm's on the second I don't drop below 110 trq till 5300 rpm's , on sheet 1 I'm at 110 trq at 4200 rpm's and on the second I'm at 116 trq at 4200 rpm's , over all I am VERY VERY HAPPY , the slight loss on the bottom you do not feel but it pulls way harder and longer when on the gas , SPECIAL THANKS to Frank Drago for the pipe , cams and knowledge and to Doc Weaver the best tuner in the USA
tj316 is offline
post #2 of 8 (permalink) Old 01-19-2013, 03:24 PM
bpt-bagger's Avatar
Those are nice numbers! That torque should feel great
bpt-bagger is offline
post #3 of 8 (permalink) Old 01-19-2013, 03:45 PM
598Malibu's Avatar
Good numbers what cubic inch?
2012 Big Blue Pearl FLTRU
72 Chevelle with Procharged 598
598Malibu is offline
post #4 of 8 (permalink) Old 01-19-2013, 03:49 PM
Re: Docs-Dragula & T Man
Looking good tj316, I bet it sounds good also.
Sent from my SPH-L710 using Motorcycle.com Free App
post #5 of 8 (permalink) Old 01-19-2013, 03:54 PM Thread Starter
tj316's Avatar
it is a 103 motor
tj316 is offline
post #6 of 8 (permalink) Old 01-19-2013, 05:19 PM
torqu's Avatar
Sure looks like good #'s
torqu is offline
post #7 of 8 (permalink) Old 01-21-2013, 12:38 PM
Looks kick ass nice tq with cam and exhaust change only.... Nice to see real numbers from a dyno. Not BS
DragoBikeWorks is offline
post #8 of 8 (permalink) Old 01-21-2013, 01:12 PM Thread Starter
tj316's Avatar
Frank , the little I lost on the front you do not feel at all , but it pulls much stronger and longer in the mid range to top end , I did a rolling start with a buddy whose bike and mine ran about equal before , by the time I hit 6 gear I had 5 or 6 bike links on him , I am very happy , THESE ARE TRUE NUMBERS by a HONEST TUNER , these are not stretched numbers by someone with a HAPPY TUNER and Kit like we keep seeing TJ
tj316 is offline
Boom Audio Parts & Instructions Docs? Bear714 Audio 3 10-30-2014 07:13 AM
Just got my bike back from Docs KneesInTheBreeze *General Road Glide Discussions/Pictures 19 08-01-2013 09:41 PM
117 with Docs map digga25 Dyno Results 1 03-27-2013 11:56 AM
107", T-man T-555TQ, Dragula 2-1 Hullhorr Dyno Results 10 12-10-2012 08:58 AM
