Jims 135 Stock with Dragula Fang 2012 RG - Road Glide Forums
post #1 of 6 (permalink) Old 01-31-2013, 02:03 PM Thread Starter
Here is what we did so far with 100 miles on bike. We did not rev past 5700/5800 rpm.
We did 3 pulls SAE SM 5
4th
5th
6th
We have 100 miles on it and here is what we got so
We did 3 pulls 248 engine temp
4th gear 125.90HP 128.94TQ
5th gear 126.63HP 133.24TQ
6th gear 128.78HP 136.56TQ
Pulls you can see the differecne between 4 and 5 and 6 gear.
All stock 135 with Dragula Fang pipe.
wide open 13.afr pulls
13.8 cruise range.
Again this motor is new with some more miles on her and some more tuning I think we can get 130/135hp out of her.
But she runs real strong.... smooth........
DragoBikeWorks is offline
post #2 of 6 (permalink) Old 01-31-2013, 03:27 PM
PFWiz's Avatar
I was very interested to see the actual difference 4th, 5th and 6th gear really make. I knew that a 6th gear dyno run gave better numbers, but I never knew exactly how much better.
Now when I look at different runs done in different gears I will be better able to compare them apples to apples.
Thanks Frank.
PFWiz is offline
post #3 of 6 (permalink) Old 01-31-2013, 04:05 PM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Wiz, on HD late model bikes 6th gear is 1:1 and will yield "actual" HP and Tq. 1:1 is a true representation as 4th or 5th gear runs will have slightly lower numbers due to gear reduction and parasitic loss, it is simple laws of physics. Depending on the specific bike, tuning product, and combination, many times you are not able to make runs in 6th, so runs are made in 5th. Regardless, looks like this 135 is a nice combination
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #4 of 6 (permalink) Old 01-31-2013, 04:50 PM Thread Starter
Heres a basic lay out of Gears ratios on your 09 and up.
34 Engine
46 Clutch Sprocket
32 Trans Sprocket
68 Rear Wheel pulley.
1.35 Primary Drive (Engine to Transmisson)
2.125 Final Drive (Transmisson to Rear Wheel)
2.875 Over all drive
2009 to 2013 baggers above......
1st 9.312 over all 26.772
2nd 6.421 over all 18.460
3rd 4.774 over all 13.725
4th 3.926 over all 11.287
5th 3.279 over all 9.427
6th 2.90 over all 8.337
post #5 of 6 (permalink) Old 01-31-2013, 11:28 PM
Not bad numbers but for 9k and 135ci I would think it would be a little more. I am sure it runs strong though
2011 Sedona Orange FLTRX, 124" S&S, D&D Boarzilla, 66mm Thottle Hog, Streched and Custom
piesik650 is offline
post #6 of 6 (permalink) Old 02-01-2013, 08:43 AM
JacktheBagger's Avatar
for 9 grand I'd give Frank the go ahead and prolly beat the pee outta those numbers with my motor ..
Nevre figgered why , but peeps will dump 9 grand into a crate motor , when for way less than that , Frank could build your motor further than the stock 135
JtB
2011 Ultra
JacktheBagger is offline
Problem with new turn signals...Ciro Fang Front Signal Inserts pappy66 Tech Area 5 03-28-2018 05:01 PM
Jims 135 in a 2012 Road Glide install coming DragoBikeWorks Engine Related 34 01-31-2013 02:01 PM
jims 135 nanook Engine Related 10 01-30-2013 09:06 AM
