I KNEW I should NOT have done a dyno.... - Road Glide Forums
 12Likes
post #1 of 33 (permalink) Old 09-25-2016, 08:57 AM Thread Starter
Spazz's Avatar
I now know the truth on my 120ST.... not that impressive if you ask me. Being in Reno, I know my numbers would/could be much better out near the coast... Im at 4500ft.
So.. here is what I have
Power Vision
Target Tune wideband O2 module
1074X Thunder Header
Chisel Extreme AC
Conditions:
83 degrees.... 25.56 in-Hg.... 17% Humidity and STD 1.19
Ready?
105.11 HP and 114.59 TQ
I knew I should NOT have done it.... oh well... it was done by Dyno Jet on their mobile dyno.... so it was not a DETAILED dyno for $190..... AFR's were all over the map and they smoothed them out nicely....runs better, so I have that now... LOL
RENO BAGGER AUDIO
Spazz is offline
post #2 of 33 (permalink) Old 09-25-2016, 09:10 AM
RFG7680's Avatar
I would have expected a lot more too. My 11 RGU 103 with 590 cams and mild head work hit 100hp-110tq.
Are you running true duals? I'm going to assume so. 2-1 will net more.
RFG7680 is offline
post #3 of 33 (permalink) Old 09-25-2016, 09:12 AM
Wow! That's not real impressive, that's the #'s that a 103 stage 2 is producing. I am sure it put a on your face.
Spazz likes this.
post #4 of 33 (permalink) Old 09-25-2016, 09:14 AM Thread Starter
Spazz's Avatar
Nope... listed my 2-1 1074X Thunder Header in the post with all the rest... tuner, module and AC
RENO BAGGER AUDIO
Spazz is offline
post #5 of 33 (permalink) Old 09-25-2016, 09:16 AM Thread Starter
Spazz's Avatar
No shit Mark.... when he told me... I laughed and said... no.... really... whats my numbers? his response didn't change....I needed another beer at that point... LOL!!!
RENO BAGGER AUDIO
Spazz is offline
post #6 of 33 (permalink) Old 09-25-2016, 09:19 AM
I bet you had more then 1 beer, don't drink too much you need the money for a new dyno tune.
post #7 of 33 (permalink) Old 09-25-2016, 09:22 AM Thread Starter
Spazz's Avatar
Oh yeah... Street Vibrations fall rally in full swing... I had many more beers after that... LOL!
Thinkin I may go with the 124kit with headwork down the road... who knows.... FM boasts 141 HP and 146 TQ
RENO BAGGER AUDIO
Spazz is offline
post #8 of 33 (permalink) Old 09-25-2016, 10:58 AM
RFG7680's Avatar
Ya. I tried editing my post but it's taken an hour to log on. Someone through out the anchor on my data plan. It's soooooo slow today. May just be RG.org.
RFG7680 is offline
post #9 of 33 (permalink) Old 09-25-2016, 11:21 AM
SMOKENJOE's Avatar
LOOKS LIKE YOU ARE IN THE BALL PARK FROM HARLEY
Harley-Davidson Press Release:
Take a Harley-Davidson® Touring bike to the wild side of performance with the new Screamin’ Eagle® SE120ST Crate Motor from Harley-Davidson® Genuine Motor Parts and Accessories. Offering the ultimate in factory-engineered street performance, this 120-cubic-inch engine is designed for bolt-in installation in an Original Equipment-style Harley-Davidson Touring chassis with no required fabrication or engine mount relocation.
Equipped with a Screamin’ Eagle 58mm Throttle Body that’s 18 percent larger than stock, this engine is capable of producing 106 horsepower and 117 lb-ft of torque at the rear wheel. The crankcase, cylinders and heads are painted black and feature machined aluminum highlights and chrome covers.
Features:
• 4.060 big-bore cylinders
• 4 5/8-inch stroke SE Pro stroker flywheel and rod assembly
• 10.5:1 high-compression nickel-plated forged pistons with Teflon® coated skirt
• Titanium SST piston rings
• SE-259E high-lift cams
• Perfect Fit push rods
• SE high-performance lifters
• CNC-ported MVA heads with automatic compression release
• SE Pro High-Flow 58mm EFI Throttle Body, high flow injectors and manifold clamps
• Machined lower rocker boxes for valve spring collar clearance
• Factory-machined engine cases
• Unique piston oilers for stroker clearance
• SE inner crankcase full complement cam needle bearings
• SE Lefty high-performance crankcase output bearing and nitride bearing race
• SE Performance spark plugs
• 120ST cam cover and cylinder head medallions
Fitment for the Screamin’ Eagle SE120ST Performance Crate Engine is:
- 49-state 2015-later Touring models. Does not fit Twin-Cooled™ models.
- Certification is pending for California 2015-later Touring models.
- Certification is also pending for all 50 states 2010 – 2014 Touring models.
Engine includes a one-year warranty. See an authorized Harley-Davidson dealer for details. Labor costs not included.
MSRP: $5,695.00
SMOKENJOE is offline
post #10 of 33 (permalink) Old 09-25-2016, 01:08 PM
hd4cruzin's Avatar
Spazz,
Take a ride to Hayward CA and have Bob @ RC Cycles tune your bike. He is amazing and should be able to tune that bike right. I ride all the way up from S. Cal to have him tune my bikes. I don't trust anyone else.
I have a 103 with Drago's 580 cam and Drago II 2-1 pipe getting 105/115. based on your #'s I don;t think I would go 120. Lol
You're close enough you could ride over in the morning, Dyno mid day and be home for a late dinner.
Bill
007xd9 and turbochrisb like this.
2012 FLTRX BBP
hd4cruzin is offline
I knew it! Damn Groundhog!!! Ohiobellboy General Off-Topic Discussions 13 03-25-2013 10:05 AM
What we already knew... Marion *General Road Glide Discussions/Pictures 4 05-09-2012 05:51 AM
But you guys already knew that ... Speedie *General Road Glide Discussions/Pictures 10 04-24-2012 02:08 PM
Should I or should I not? Howardsternspenis Clothing 22 03-31-2012 09:07 AM
Should I or should I not Runto77 Aftermarket Accessories 2 09-10-2010 06:04 AM
