First dyno run on the new engine/cams - Road Glide Forums
 5Likes
  • 2 Post By Stick_FSMC
  • 1 Post By Stick_FSMC
post #1 of 8 (permalink) Old 10-22-2016, 09:43 PM Thread Starter
Stick_FSMC's Avatar
When I had the engine replaced this last summer, I got the cams upgraded from SE255's to SE259E's. Everything else was virtually the same as before.
Today, I was able to get a dyno pull on the new set up. No tune, just a pull.
I was quite pleased with the results.
Before:
HP - 97.12
Torque - 117.88
After:
HP - 112.9
Torque - 122.8
An increase of 15 HP and 5 lb/ft of Torque is better than I expected.
I don't have the new curve chart yet, but those are the numbers I was shown. The new chart should be emailed out on either Monday or Tuesday. I'll post it as soon as I have it.
Swomack and BG1960 like this.
Stick
USAF 1980-84
Stick_FSMC is offline
post #2 of 8 (permalink) Old 10-23-2016, 07:57 AM
SteadyEddie's Avatar
Dig it Daddy-0..........congrats
SteadyEddie is offline
post #3 of 8 (permalink) Old 10-23-2016, 10:13 AM
turbochrisb's Avatar
And you attribute that soley to a cam change? That's huge if so. I bet 122 ft lbs is a blast to ride!
turbochrisb is offline
post #4 of 8 (permalink) Old 10-23-2016, 01:55 PM
Swomack's Avatar
Good Numbers Brother
My Gallery / Click Below Link
Swomack is offline
post #5 of 8 (permalink) Old 10-23-2016, 06:00 PM Thread Starter
Stick_FSMC's Avatar
I can't call it just the cams, as it is a whole new engine, but I had the 110" with the exact same setup with the exception of the SE255 cams in the original engine and got the 97/117 numbers twice in a 6 month period, just a few months before the engine had a cam tensioner go bad and send metal fragments through out the engine.
I got the 110" longblock replacement engine and had the SE259E cams put in it after the first engine went south on me. 2500 miles later, I got the dyno numbers run again and got the 112/122 numbers yesterday. So I can't claim it was just a cam change, but I would tend to think the cams had a lot to do with it since all the other major systems (intake, exhaust, tuner) were the same.
Either way, it is a blast to ride and I'm enjoying the hell out of it.
turbochrisb likes this.
Stick
USAF 1980-84
post #6 of 8 (permalink) Old 10-23-2016, 06:17 PM
Thanks and yeah, it must be a riot to ride.
post #7 of 8 (permalink) Old 11-09-2016, 01:16 PM Thread Starter
Stick_FSMC's Avatar
I finally got the chart for my dyno pull from 10/22/2016. It got delayed because of a typo in my email address.
Comparing this to the pull from 3/19/2016 and you can see that the peaks have moved up and to the right on the charts.
Still hits 100Ft/lb of torque at approximately the same place. ~2800rpm now vs ~2700rpm before
10/22/2016: Max Power 112.91 bhp @ 5633.5 rpm, Max Torque 122.78 Ft/lb @ 4122.6 rpm
03/19/2016: Max Power 97.12 bhp @ 4918.6 rpm, Max Torque 117.88 Ft/lb @ 3865.5 rpm
AFR is still a little lean, but it looks better than it did in March. It's a lot flatter now. Not too shabby for a canned map!
turbochrisb and BG1960 like this.
Stick
USAF 1980-84
post #8 of 8 (permalink) Old 11-12-2016, 08:24 AM
cool
fenmore is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 08:18 AM
First Dyno Run jlspiker Dyno Results 10 02-10-2012 02:53 PM
11 serg dyno run DOOFUS Road Glide Specific Discussions 12 01-09-2011 09:30 PM
Dyno Run from Direct Link Install Shrug ECM/Fuel Management systems 6 06-07-2010 09:32 AM
Dyno run On You Tube pte359 *General Road Glide Discussions/Pictures 5 05-21-2010 07:48 PM
