2016 FLTRU 110 kit dyno - Road Glide Forums
 4Likes
post #1 of 25 (permalink) Old 02-05-2017, 09:16 AM Thread Starter
I have a 2016 RGU 103, which over the holidays I had a Harley 110 kit installed.
VH naked v02 a/c
VH power duals
VH twin slasher slip-on
SE 585 cams
10.2:1 compression
4" cylinders
Power vision
Let me know what you guys think. It's seems a little on the low side to me, compared to other builds I've seen posted.
BARSR likes this.
otter10111 is offline
post #2 of 25 (permalink) Old 02-05-2017, 03:13 PM
Darreldanger's Avatar
Yep
Darreldanger is offline
post #3 of 25 (permalink) Old 02-05-2017, 03:20 PM
Just about what mine got. I to was believed/hoping I was putting out more HP. But your mods and dyno really smoothed out the motor over the entire length of the run, plus you have awesome power gains from the original run. Nothing to be ashamed of there brother. Better hang onto these bars a bit tighter now. Bet it feel like the front end is ready to lift off now too!
BARSR likes this.
Illegitimus non carburundum. Or something to that effect. Jack of all trades, master of none.
Diverrick is offline
post #4 of 25 (permalink) Old 02-05-2017, 03:24 PM Thread Starter
I'll be getting my bike back Tuesday they're replacing my warped front rotors under warranty. They didn't have the rotors in stock. I'll post some screen shots of the tune once I get it downloaded on my computer.
post #5 of 25 (permalink) Old 02-05-2017, 03:30 PM Thread Starter
It's definitely more responsive, even riding two up. I'm not really disappointed, it's a blast to ride. I can always add more later, heads port and polished, throttle body, or just up grade to a 107 then to 114.
post #6 of 25 (permalink) Old 02-05-2017, 08:37 PM
Stick_FSMC's Avatar
My first run on the 103 to 110 big bore conversation was with the V&H power duels/High outputs, SE Heavy Breather, SE255. It posted 97bhp - 117 Ft/lb.
When I traded out the SE255's for SE259E's, it jumped up to 113bhp - 123 Ft/lb.
I hope that comparison helps.
Stick_FSMC is offline
post #7 of 25 (permalink) Old 02-05-2017, 09:02 PM Thread Starter
That's crazy I asked the dealer if I should change the cams to the SE 255 or the 259 they said stay with the 585.
post #8 of 25 (permalink) Old 02-05-2017, 09:40 PM
MyGlide's Avatar
Does seem a little low especially since it's done in STD correction factor. STD generally shows about 4% higher than SAE which is more widely accepted.
2018 FLTRU (mistake)
2018 KTM Super Duke R
MyGlide is offline
post #9 of 25 (permalink) Old 02-05-2017, 09:48 PM Thread Starter
Can I have the shop convert the std to SAE? Not sure I would want to know what those numbers are. I my mind it does rip for sure. I don't know if a cam change will be in my future but I'm gong to ride the sh_t out of it.
post #10 of 25 (permalink) Old 02-06-2017, 09:06 AM
Stick_FSMC's Avatar
That's all that really matters. Have Fun, Enjoy the Hell out of it, and just Ride!!
Who cares what the numbers are, if you're happy with it, enjoy it.
Stick
USAF 1980-84
2016 FLTRU dyno numbers scubaz71 Dyno Results 6 05-14-2017 02:12 PM
SE 110 & MVA Fuel Moto 110 Drop in & 107 piston/cylinder kits now available fuelmoto Fuel Moto 0 03-16-2017 04:22 PM
2016 RGS w/110" stage 3 dyno sheet NHBOUNCER Engine Related 9 12-26-2016 05:57 AM
New 2016 FLTRU 110 upgrade advice Manshoon Engine Related 17 01-04-2016 10:27 AM
Dyno sheet 110 SE 260 cams Yellow09SERG Engine Related 27 02-10-2012 06:51 AM
