110 drop in, CVO w/Mods, 117 drop in - Road Glide Forums
post #1 of 2 (permalink) Old 03-08-2017, 07:44 AM Thread Starter
Lou Dude's Avatar
Here's some dyno charts of my previous and current bikes.
We did a 110 bolt on kit with my old SG.
Had a local shop port the heads, 58mm TB, SE Clutch, BoarZilla, 259 Cams and was realistically about 10.2 / 1 compression. Comparison dyno chart with my new 117.
The CVO when I bought it had 259 cams, HD pop up pistons, and a Rinehart true duel set up. We could've got more out of it on the dyno but I was itching to get the kit put in it. And I hated the sound with those Rineharts.
In the new bike we did Surburban Speed's 117 bolt on kit, .030 head gasket, AIM lock up clutch, kept the 259's, added the 58MM TB from my old bike and a brand new BoarZilla. This is with 100% stock CVO heads, as the came from the factory. It's right at 11 to 1 compression. And it fucking thumps.
Have a friend who had a similar build to my old bike, he made 2 more hp and 2 more torque. We've run the new bike against his several times and its no contest. The orange bike just walks away.
Anyone contemplating the 117 kit, I say go for it. Lots of room left if I want. Torque everywhere, it's definitely an arm puller. And with my itty bitty wife on the back it's hard to keep the front wheel on the ground.
2013 CVO Road Glide.
Has a few mods.
Lou Dude is offline
post #2 of 2 (permalink) Old 03-08-2017, 07:59 AM
SteadyEddie's Avatar
I can dig it....
SteadyEddie is offline
16RGS, 110 drop in, T-man 585 cam Smarty Dyno Results 16 05-04-2017 11:05 AM
SE 110 & MVA Fuel Moto 110 Drop in & 107 piston/cylinder kits now available fuelmoto Fuel Moto 0 03-16-2017 04:22 PM
New Extreme Duty 98" 107" & 110" Drop In Fuel Moto Cylinders fuelmoto Fuel Moto 0 12-13-2016 11:54 AM
117" Drop In rg113 Engine Related 18 01-26-2016 05:54 AM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 09:31 AM
