16RGU Stage 1 Dyno Run only - Road Glide Forums
 2Likes
post #1 of 13 (permalink) Old 03-19-2017, 12:42 PM Thread Starter
BlazingSaddle's Avatar
After a Stage 1 upgrade, Fuel Moto 2-1-2 SS ceramic coated pipe, Fuel Moto Pro billet A/C, Powervision tuner and RCX exhaust, curiosity got the best of me. Don't have my stock map for comparison, but just felt like I lost low end torque since the upgrade, hence the Dyno run. My bike's tune is with a map Fuel Moto provided when I purchased it, coupled with a few of my own Auto Tune runs. Prior to the Dyno run, conversations with Brian at Fuel Moto lead to the RCXs possibly being source of torque problem. While the numbers seem to be ok, I mentioned seat of pants felt 60-70hp and 70 tq at best. Was really surprised at the Dyno results, expected much worse. Torque still comes in too late for my liking. Also, AFR has a bad bump at the outset and looks to run a little lean overall. The AFR is spot on, oddly enough, where torque takes a dip. Seat of the pants ride is unimpressive, except in 2nd gear running about 3000rpm. Bike jumps like a rabbit and scoots, but that's not where I ride in the powerband. Tuner said the drop could be caused by reversion, (so pipes) but not sure. Said an actual tune could get a much better torque curve. Anyway, Fuel Moto will work with me and hopefully with this additional info they might be able to tweak it. I'm not tuner competent enough to mess with it. A very good tuner should be here for Thunder Beach, and I trying to decide on a cam so holding off on a spendy tune just yet. Thoughts or comments (good or bad) from those in the know are welcome. Thanks!
BlazingSaddle is offline
post #2 of 13 (permalink) Old 03-19-2017, 07:37 PM
This dyno is from HD Screamin Eagle Parts Book. Check out the 103HO stock dyno #'s & TQ is 90 lbs.
Screamin' Eagle Bolt-On 110 Stage III Street Performance Kit | Performance Kits | Official Harley-Davidson Online Store.
First I pulled up the 103HO with 585 cams & it shows the TQ is 80 lbs. Must be a miss print. Other than the dip in TQ it looks good. Good luck
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 13 (permalink) Old 03-19-2017, 09:53 PM Thread Starter
Thanks Hillglide. At 2.5k, the STOCK setup on the graph you provided shows about 8-9lbs MORE TORQUE than my Stage 1, so the loss of torque in my seat of the pants dynometer was right. It'll scoot, but again, later than where I want it. It's that dip in torque, and a flatter AFR I hope can be tweaked.
I'm going to try and get my tune and dyno sheet to Fuel Moto some time this week. They've helped me in the past, and more than willing to help now, so that's encouraging.
No doubt, 80lbs of torque with the 585s doesn't sound right. Was actually looking at that cam, but pretty sure I've narrowed it down to a Wood TW222, or TW555.
post #4 of 13 (permalink) Old 03-20-2017, 08:47 AM
I see your in Florida, not sure where though. I got my bike back from H&D in Lillian AL 2 weeks ago. Heath broke the motor in and tuned it. Bike runs incredibly smooth and pulls real hard. Heath is a good dude and jam up tuning bikes.
Ive read on many sites that there a good/great tune makes the build. I can verify that statement is completely true.
H&D is a mile or so across the state line. Easy run from Panama City beach.
phillyfan1 is online now
post #5 of 13 (permalink) Old 03-20-2017, 09:33 AM
sloride's Avatar
Your only above 90 lbs TQ from 2800 RPM to 4500 RPM. That's only 1700 RPM's of decent power band. Combine that with that early power dip and that is going to make for a very unresponsive motor. A good tuner can help some with that early dip and give you some more throttle response, but those mufflers are not helping either.
You have a good Peak TQ #. Your Averaged TQ # from 2000 RPM to 5000 RPM is not very good
A good set of TQ building mufflers and a "good" Dyno tune will make a big difference in throttle response.
sloride is offline
post #6 of 13 (permalink) Old 03-20-2017, 10:19 AM Thread Starter
Originally Posted by sloride View Post
Your only above 90 lbs TQ from 2800 RPM to 4500 RPM. That's only 1700 RPM's of decent power band. Combine that with that early power dip and that is going to make for a very unresponsive motor. You have a good Peak TQ #. Your Averaged TQ # from 2000 RPM to 5000 RPM is not very good
Sloride, you hit the nail on the head and described exactly what's going on - unresponsive bike. All bark, no bite. 1700RPMs of decent power in the power band go by quickly, and it no sooner kicks in before it starts petering out. Been looking for decent slip ons since the start of this venture, and seems like many are running either the stock CVO pipes, or the CVO pipes with full sac baffles. So either those for the quiet factor my passenger prefers, but also leaning towards the new Jackpots for starters. I agree, a dynotune is in order, but really thought a map and a few autotune sessions would get me in the ballpark for the small improvement in performance I was anticipating. Brian told me to just put my stock pipes on and see if it made a difference. I'm sure it will, and plan on doing that today since I have the day off.
Thanks Phillyfan. Followed some of your posts regarding your build and yours and Dragon Dude's high regard for H&D. They're definitely within riding distance and definitely worth a shot when I get that far into it (cams). Any idea which tuner they're most comfortable using?
Thanks for the input, all. Much appreciated.
post #7 of 13 (permalink) Old 03-20-2017, 11:25 AM
TTS or PowerVision is what we talked about. I went with the TTS
BlazingSaddle likes this.
post #8 of 13 (permalink) Old 03-21-2017, 07:09 AM
Did you put headpipes on or are you still running stock headpipes with the catalytic in them. If you're running stock headpipes then either pull the cats out of the pipes or put on aftermarket headpipes. It may not cure all your problems but a free flowing exhaust will help.
post #9 of 13 (permalink) Old 03-21-2017, 07:43 AM Thread Starter
Thanks Ironmark. Yes, my Stage 1 consists of a Fuel Moto 2-1-2 Headpipe, Fuel Moto Pro billet A/C, Powervision tuner, and what I think is the weak link - the RCX mufflers. Oddly, was told perhaps I have too much flow with the RCXs and need more back pressure. Love the sound of the system, but will sacrifice sound and looks for a better running machine (to a certain point, drawing the line at 2-1). Sent Fuel Moto my map and Dyno Run for their recommendations and currently waiting for a reply.
post #10 of 13 (permalink) Old 03-21-2017, 08:38 AM
08Zinc's Avatar
I have a 15 RGS and just did the Jackpot 2/1/2 headers and Jackpot Hi-Roller exhaust. With the 555 cam, there is no dip in torque and the difference from what I had was remarkable. No dyno runs, just Power Vision with Target Tune. But seat of the pants is super impressed.
Blessings, Zinc -
08Zinc is offline
M8 stage 4 Dyno run Churchburner Dyno Results 11 03-02-2018 01:13 PM
Pics only....is it possible to only keep pics in this post?! LOL! Chicago Harley Boy *General Road Glide Discussions/Pictures 132 06-17-2013 10:18 AM
Dyno Run from Direct Link Install Shrug ECM/Fuel Management systems 6 06-07-2010 09:32 AM
Dyno run On You Tube pte359 *General Road Glide Discussions/Pictures 5 05-21-2010 07:48 PM
