2016 FLTRU dyno numbers - Road Glide Forums
  • 1 Post By scubaz71
post #1 of 7 (permalink) Old 05-13-2017, 07:43 AM Thread Starter
scubaz71's Avatar
Well I put Cams in and had a tune today. Not too bad of numbers I don't think. Twin cooled, screamin eagle intake, T-man 555 Cams, race tuner.
scubaz71 is offline
post #2 of 7 (permalink) Old 05-13-2017, 08:46 AM
Good numbers 107 torque will give you a nice ride. Did you do a exhaust upgrade? Gutting or eliminating the cat or a good aftermarket head pipe with good mufflers may get you a little bit more.
post #3 of 7 (permalink) Old 05-13-2017, 08:55 AM
BlazingSaddle's Avatar
Am I reading this wrong? The sheet says 107TQ, but the graph line looks like it's hovering around 95. Question is, what's your seat dyno telling you? Which 2-1 pipe are you using?
BlazingSaddle is offline
post #4 of 7 (permalink) Old 05-13-2017, 11:08 AM
hd4cruzin's Avatar
Dyno graph looks odd.....Lines cross at approx 4,600 RPM and torque curve is not as high as text says it came out at.
2012 FLTRX BBP
hd4cruzin is offline
post #5 of 7 (permalink) Old 05-13-2017, 05:20 PM Thread Starter
scubaz71's Avatar
I am running a Dragula 2 exhaust and the seat of the pants dyno is flipping great. I am very happy with it.
BlazingSaddle likes this.
scubaz71 is offline
post #6 of 7 (permalink) Old 05-13-2017, 07:25 PM
The second dyno looks like the graph is at the wheel but the listed numbers is calibrated at the crank.
My guess
2016 ROAD GLIDE SPECIAL
evomind is offline
post #7 of 7 (permalink) Old 05-14-2017, 02:12 PM
That cam and pipe look like they work good together. Goods there, and good choice getting it tuned
Nice job
phillyfan1 is offline
2016 FLTRU 110 kit dyno otter10111 Dyno Results 24 04-09-2017 09:59 PM
Finally have my dyno numbers on cam install FLtroll Engine Related 18 11-03-2014 11:03 PM
2012 fltru stock cam numbers DOOFUS Engine Related 11 11-15-2012 03:04 PM
What numbers should I see after dyno? mikeshog Engine Related 28 10-16-2011 02:45 PM
My dyno numbers Eric92 Dyno Results 3 07-22-2011 11:29 PM
