02 RG- Thunderheaders 2:1, SE253 cams, SE 95ci w/ 10.25:1, SE A/C, PC-III, Blueprinte - Road Glide Forums
post #1 of 6 (permalink) Old 04-12-2013, 03:07 PM Thread Starter
adrenilinecrash's Avatar
So I took my scoot to the dyno finally. I was hoping for bigger number but I am happy with the results. My best pull was 87hp/95tq. It's not on the pic. The dyno tech didn't put it up for some reason but whatever. Numbers aren't the important part. The important part is the a/f graph and the torque curve. If you notice it pulls all the way to stock recline. This tells me I need beadwork. So I'm starting to save now lol.
So what do y'all think??
-Mike
02 FLTRI
15 FXDL
adrenilinecrash is offline
post #2 of 6 (permalink) Old 04-12-2013, 04:16 PM
SpringerTodd's Avatar
That's just about exactly what I pulled with my 09 96"ImageUploadedByTapatalk1365801319.374791.jpg
Thank a Vet for your freedom!
God Bless America!!
2009 FLTRI Dark Blue Pearl "Stormy"Zippers Performance 107" Sport Build, Bub 7: 2 into 1, RSD Turbine, TMax 125/125, 2002 FXSTSI "Justine" Springer Custom, lots of goodies.
SpringerTodd is offline
post #3 of 6 (permalink) Old 04-12-2013, 10:04 PM Thread Starter
What'd you have done?
02 FLTRI
15 FXDL
post #4 of 6 (permalink) Old 04-12-2013, 11:38 PM
Bandit's Avatar
91 Hp & 106 ft/lbs
S&S 97" Big Bore Kit 9.7:1 Compression
570G Gear Drive Cams
Fueling RS Lifters
Fueling HP Adjustable Push Rods
Fueling Race Series Oil Pump
TTS Mastertune - Tuned by Pike's Peak Harley Davidison
This setup was originally tuned using old 3.5" Rinehart True Duals. Since then I ran Dragos True Duals for awhile, and now I'm running the Klock Werks Double backs and soon CFR Slip-ons.
American Motorcycles from Colorado Springs, Co. did the work last summer. I was very happy with the results! My bike runs fantastic, has a wicked idle, and pulls like a freight train.
All of this was with ZERO headwork so far. That's next on the agenda so I can take full advantage of the build.
2005 FLTR - 97" S&S Big Bore, Hillside Cycle Stage II Heads & Throttle Body Upgrades, S&S Rollers, Fueling Pump & Lifters, 570G Gear Drive, TTS, CFR's, Klock Werks Double Back, 104hp/106ftlbs. CB's Euro, PM Light Glide LED Kit, RC CZar Wheels
Bandit is offline
post #5 of 6 (permalink) Old 04-13-2013, 04:46 AM Thread Starter
Yup. Headwork. That's my next item. I can't wait. Seein everyone with 97/98 kits makes me want to upgrade. Those are good numbers though. I love the fact the 88 is one of the best engine Harley built.
02 FLTRI
15 FXDL
post #6 of 6 (permalink) Old 04-14-2013, 06:21 AM
tj316's Avatar
had an 88 on my last bike , punched it out to a 95 with head work and more and that bike was fast and much cooler than the 103 motor
tj316 is offline
thunderheaders with extended saddlebags bbrunnett Intake and Exhaust 2 02-01-2015 10:21 AM
thunderheaders exhaust bbrunnett Intake and Exhaust 14 03-13-2013 06:08 PM
Map for PC III USB for 06 RG kimmer127 ECM/Fuel Management systems 2 10-15-2010 03:18 PM
06 95ci 54gs WFO Larrys Heads Corrupted Engine Related 1 08-08-2010 07:17 PM
Woods TW6H CAMS OR SE251 IN 95CI tr17047 Engine Related 2 06-23-2010 11:02 AM
