2015 RG Special Dyno Results - Road Glide Forums
 6Likes
post #1 of 22 (permalink) Old 09-12-2017, 03:10 PM Thread Starter
Cdan19's Avatar
SE 259E Cams, V&H 2 in 1 Pro Pipe with S&S Air Cleaner resulted in : 100.14 HP and 105.65 Torque. Dean at MnM Cycle Tinley Park, IL on the parts install and Jimmie at Illinois Harley, in Countryside IL on the Dyno Tune.
Cdan19 is offline
post #2 of 22 (permalink) Old 09-12-2017, 03:20 PM
Thumbs up
2015rgs with stageIV kit-105 h.p.-115 torque
Cdan19 likes this.
nanook is offline
post #3 of 22 (permalink) Old 09-22-2017, 05:46 AM
Tuner
What tuner are you using to tune it with ?
2016 Road Glide Ultra Superior Blue
freedom1974 is offline
post #4 of 22 (permalink) Old 09-22-2017, 01:02 PM
Thumbs up
Power Vision.
freedom1974 likes this.
nanook is offline
post #5 of 22 (permalink) Old 09-22-2017, 05:28 PM
Good deal. That's what I have.
post #6 of 22 (permalink) Old 09-25-2017, 02:25 PM
Buck8866's Avatar
2009 Road Glide 103 upgrade, Ported Heads, 777Cams, 58mm Throttle Body, Stage 1, Two into One Thunder Header exhaust, Screaming Eagle Tuner 112HP- 115Torque
Buck8866 is offline
post #7 of 22 (permalink) Old 09-25-2017, 02:46 PM
Jeff_S's Avatar
Nice numbers.
2017 Mysterious Red Sunglo/Velocity Red Sunglo RGU
Street Cannons, Ventilator Air Cleaner, Pro Street Tuner
Jeff_S is offline
post #8 of 22 (permalink) Old 10-06-2017, 10:30 AM
johnson27's Avatar
Very Nice numbers
johnson27 is offline
post #9 of 22 (permalink) Old 10-19-2017, 01:15 PM
Are you on stock Pistons, head gasket and heads? Do you have a chart that you could post?
Dvs624 is offline
post #10 of 22 (permalink) Old 10-19-2017, 11:13 PM
IdahoHacker's Avatar
Sweet! Numbers are right in line with mine. Ain't that Pro Pipe awesome!!
Cdan19 likes this.
2015 FLTRXS, SE Ventilator A/C, V&H Pro Pipe, S&S/Crane Chris Rivas Rocket 574 cams, Chris Rivas V-Twin dyno tune: 103 hp, 108 tq.
IdahoHacker is offline
2015 RGS dyno results Spazeack Dyno Results 20 09-07-2016 09:50 AM
2015 RGS 113" Dyno Results Bigracks Dyno Results 5 12-03-2015 09:50 PM
2015 RG Stage One Dyno results Avalanche123 Dyno Results 23 07-31-2015 07:29 AM
2015 Limited stage 1 Dyno results dynoguymn Dyno Results 3 07-02-2015 11:13 AM
2015 RoadGlide Special Dyno Results platinumnj Dyno Results 15 03-03-2015 06:50 AM
