'18 114-in Stage=4 with TTS cams and TTS tuner - Road Glide Forums
 5Likes
post #1 of 13 (permalink) Old 12-12-2017, 09:38 PM Thread Starter
Sharkbreath's Avatar
After shitty service from the Spacecoast Stealership, I took my sputtering and coughing '18 RG Special to Doc's Performance Tuning in Mineola Florida. Doc has already built two of my previous CVOs into monsters so i felt pretty comfortable he could fix the mess the Stealership service department had caused. With only 1,500 miles the bike was trying to stall when I dropped the clutch and the check engine light was throwing rear O2 sensor codes. Doc removed the HD 515 crap cams and replaced them with TTS 200s. After new cams, lifters, push rods and a TTS tuner it was time for the Dyno. Doc turned my POS into a 123.5 HP / 123.3 ft/lbs of stump-pulling torque rocket ship. Doc is the master. He has added so much performance to my investments over the years and improved the reliability over the HD prescribed offerings.
File Type: jpg 12-12-17 DYNO 114' stage 4 with TTS 200 Cams and TTS tuner.jpg (343.3 KB, 171 views)
DED HD, eddienelson and Rubimad like this.
“Twenty years from now you will be more disappointed by the things you didn’t do than by the ones you did do.” – Mark Twain
Sharkbreath is offline
post #2 of 13 (permalink) Old 12-12-2017, 09:48 PM
ERod62's Avatar
Doc also tuned my 2012 RGC after disappointing performance from other tuner. Will not go nowhere else for engine upgrades.
No BS great service. :+1:
ERod62 is offline
post #3 of 13 (permalink) Old 12-12-2017, 09:51 PM
Doc is great and anyone who knows anything about him knows that. Only thing with the M8 is they won’t want to warranty your engine now. Space Coast will give you a great price when buying a bike, I know nothing about their service department, I usually do all my service.
post #4 of 13 (permalink) Old 12-13-2017, 07:06 AM
CapttomFLTRXinFL's Avatar
+ 1 On Docs Performance ! On my 12’ Roadglide Custom , I added the V&H power duals , twin slash slip-ons, Drak A/C , & S&S M103 cam , w/ the FP3. The FP3 just couldn’t ( or it was me ) get it “ perfect” . Bought it to Docs , he took the FP3 off & did the dyno w/ the TTS . The bike was as smooth as butter , in every gear & RPM range . Best $1000 I spent . Got 110 HP & 110 Torque . Last month I traded my 12’ , for an 18’ road glide special. I called called Doc , and express my concern over voiding my warranty. His response was, “would you rather have a bike that runs like sh** , For the next two years, or have a bike that runs perfect” . Great point, but still worried about the warranty . The #’s I am seeing on Fuel Moto website, appears the M8 will be an awesome platform for mods ! When I’m ready to Pull the trigger Doc will be the man !!!!
eddienelson likes this.
CapttomFLTRXinFL is offline
post #5 of 13 (permalink) Old 12-13-2017, 07:35 AM
Swomack's Avatar
Congrats
Those are some great numbers for sure.
Swomack
My Gallery / Click Below Link
Swomack is offline
post #6 of 13 (permalink) Old 12-13-2017, 12:02 PM
Once again, no substitute for a quality tune done by a person that knows what they are doing.
It costs a lot of money to have a bike tuned properly, between a TTS or PV, and the dyno time. However, there is NO substitute for it.
To the OP, Congrats on getting everything out of your build.
phillyfan1 is offline
post #7 of 13 (permalink) Old 12-13-2017, 06:44 PM
Wow, that cam with the stage 4 holds over 120 tq from 2,750 to nearly red line. I have the same cam in my 17 RGS with stage 3 and it drops off at 4,000 rpms. This show me what the CNC heads, TB and injectors can do. Thanks for sharing.
Mainecat is offline
post #8 of 13 (permalink) Old 12-13-2017, 07:43 PM
Wmoor004's Avatar
What tuner are you using? I recently bought the TTS200 cam for my stage III 114. What are your numbers? Thank you.
2017 Velocity Red Sun Glow 114 with a long list of monthly salaries!
Wmoor004 is offline
post #9 of 13 (permalink) Old 12-14-2017, 07:58 AM
You Pm'd me about it. A TTS. 128 tq/115 hp. His dyno sheet holds the torque further down the rpm line and pulls the same hp as torque.
Mainecat is offline
post #10 of 13 (permalink) Old 12-14-2017, 06:51 PM
Wmoor004's Avatar
I forgot. It my TBI kicking in. LOL!
Wmoor004 is offline
'18 M8 Stage IV with TTS200 cams and TTS tuner runs hot Sharkbreath Engine Related 8 06-20-2018 09:02 AM
114" M8 stage III cylinders/pistons etc... mtharston Parts for Sale 0 05-02-2018 08:58 PM
Map for Stage 3 - 114 kit Wmoor004 Map Section 7 03-16-2018 09:34 PM
2017 M8 114" TTS-200 cam Mainecat Dyno Results 4 03-13-2018 09:25 PM
Stage III upgrade from 107 to 114 available Ohiobellboy Engine Related 26 12-23-2017 09:14 PM
