2012 flht 124" lc - Road Glide Forums
 3Likes
  • 3 Post By harleytuner
post #1 of 9 (permalink) Old 02-28-2018, 11:12 AM Thread Starter
harleytuner's Avatar
2012 flht 124" lc
2012 Road Glide
S&S 124" LC crate
Baker Grudge box (street version)
MJK Chain drive
D&D Borezilla
HPI 58
SE 5.3 inj
SEPST
RGKen, MyGlide and Hawkman like this.
harleytuner is offline
post #2 of 9 (permalink) Old 03-26-2018, 07:45 PM
apgharleymech's Avatar
That's impressive. What do you think of the new transmission?
Shiny and New '16 FLTRXS
Harley Davidson Arizona Proving Grounds
Mech Level 1
apgharleymech is offline
post #3 of 9 (permalink) Old 03-26-2018, 07:50 PM
Swomack's Avatar
Congrats Man
Great Numbers
Swomack
My Gallery / Click Below Link
Swomack is offline
post #4 of 9 (permalink) Old 06-02-2018, 05:47 AM
neverdone's Avatar
Very impressive. My 124lc was only 120,127.
neverdone is offline
post #5 of 9 (permalink) Old 06-02-2018, 07:24 AM
HOLD ON! That is a arm stretcher! DAM!
phillyfan1 is offline
post #6 of 9 (permalink) Old 07-16-2018, 09:43 AM
What exhaust are you running?
Mech Level 1
post #7 of 9 (permalink) Old 07-17-2018, 12:25 AM
NorCal's Avatar
he listed D&D Borezilla
NorCal is offline
post #8 of 9 (permalink) Old 07-17-2018, 02:59 AM
glide69's Avatar
I had similar numbers with my 124 and ran stock belt and tranny and never had issues...... I put 30 k on the 124 and the tranny had 50k on it when the 124 was installed.... The 6 speed is a solid unit....
2018 FLTRXS Wicked Red
glide69 is offline
post #9 of 9 (permalink) Old 09-01-2018, 10:43 AM
Rob-B's Avatar
Torque Monster
HP numbers are always impressive.
I spend so little time above 90 mph, I've always been more drawn by Torque numbers.
The 124 looks like the way to go.
My first performance build was in my pre-bagger days. I bought a basket case 1988 Sportster that had suffered a cam drive keyway failure amidst 5k worth of performance add ons. It was a fairly well built 88 cubic inch Axtell, with one slight and destructive oversight.
One intake valve went through a piston crown - and as destructive as this sounds, the milk crates were put up for sale for $1500. I paid cash before the guy changed his mind.
STD heads were ported by Dave Mackie, he agreed to fix them for not a whole lot of money. They had very large Baisley valves and heavy springs to control them. Andrews BV grind .590 lift cams had overloaded the keyed cam drive pinion. We replaced that with the newer splined cam drive. 0.30 cleaned up the Axtell Mountain Motor cylinders, and fitted new pistons. This had a S&S Super G carburetor and pumped out 92 HP, 98 Ft Lb - on a 470 lb stripped down Sportster.
Weight is a big deal on bikes. I recently lost 40 lbs and swear somebody added 10 HP to my Harley. I'm not quite slim, so after then next 50 lbs or so, I'll look at building the motor as a reward. Both work.
Rob-B is offline
124 s&s / 120r to 124 Vinny Engine Related 80 05-17-2015 11:58 PM
S&S 124" LC Map needed Deadstroke Map Section 4 05-13-2015 08:06 AM
ss 124 lc jaysrgu Dyno Results 17 05-12-2015 07:53 PM
Dragos 124 engine/S&S 124 JKRSDETROIT Engine Related 41 03-14-2015 10:50 AM
